[fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
    Jason Birch
    Jason.Birch at nanaimo.ca
    Tue Apr  1 14:02:24 EDT 2008
Survival of the fittest? :)
This is a pretty common situation in open source development.  New
approaches are developed independently without the legacy constraints of
existing solutions, and if the approach is successful the existing
technology either adapts or is superseded.  This allows new ideas to be
explored without disrupting the current code base and requiring
maintenance of backwards-compatibility code for dead-end ideas.
I feel that requiring the simple RFC16 ideas to work within the SDF
framework would slow development and testing of this new approach, and
would require design compromises to meet the current needs of the SDF
provider.  I would be much happier to see the proposed provider put out
there, and the SDF provider react (or not) depending on its adoption.
Jason
-----Original Message-----
Subject: RE: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
Well, from my perspective, if we go with this new format then we are in
some manner making a statement that SDF is not sufficient and that this
new provider is intended to be developed as an eventual replacement.
Regardless of the intent right now, that will, in the end, be the
result.
More information about the fdo-internals
