[fdo-internals] RE: FDO OSGeo PostGIS Provider
Greg Boone
greg.boone at autodesk.com
Fri Apr 4 17:18:43 EDT 2008
At this time, SQL Server Spatial for 3.2.x is submitted and built from the http://svn.osgeo.org/fdordbms/branches/3.2.x repository. I would really like it that we put the PostGIS 3.2.x code somewhere central so that is can be maintained and accessed by the community.
Based on previous patches and PostGIS involvement, I will add Bruno as a contributor.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, April 04, 2008 5:04 PM
To: FDO Internals Mail List; Bruno Scott
Subject: RE: [fdo-internals] RE: FDO OSGeo PostGIS Provider
This is all good news. It's great to see the PostGIS provider maturing.
For the previous 3.2 binary release of the provider, I just pulled down the 3.3 trunk version into a local 3.2 tree and built it. I may have had to change a couple things, but I don't think so. Bruno, would you be willing to do this for 3.2, or should we look at having the OSGeo SAC set up yet another repository for us? Greg, how are you handling this for the SQL 2008 provider? It would be nice if the 3.2 repositories could eventually be archived and taken offline, but given that most of the live implementations of FDO are still using 3.2, it will take a while until we get to that point.
I'm not sure how Mateusz feels about this, but I think that if the first few of Bruno's patches look good that it would be more efficient for him to be given commit access, and for Mateusz (or others) to do post-commit review.
I'm assuming that we have received Bruno's contribution agreements?
Jason
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, April 04, 2008 13:29
To: Bruno Scott
Cc: FDO Internals Mail List
Subject: [fdo-internals] RE: FDO OSGeo PostGIS Provider
Hi Bruno,
Thanks for the update. J
For 3.3/3.4, Submit your changes into
3.4 -- https://svn.osgeo.org/fdo/trunk/Providers/PostGIS
3.3 -- https://svn.osgeo.org/fdo/branches/3.3/Providers/PostGIS
Please have Mateusz review and if needed, submit those submissions
For 3.2.x
This is a trickier issue. We do not have a SVN repository available for PostGIS built on 3.2.x. We could create a new SVN repository that follows the existing 3.2.x pattern as described on http://fdo.osgeo.org/roadMap.html
This repository name would be: http://svn.osgeo.org/fdopostgis/branches/3.2.x
You would need Jason or Frank to help you with this.
Once all the submissions are in, we can kick off the respective 3.2.x and 3.3.x builds and post patches on fdo.osgeo.org.
Greg
Sent: Friday, March 28, 2008 7:30 AM
To: Greg Boone
Cc: Gwenael Bachelot
Subject: RE: FDO OSGeo PostGIS Provider
Hi Greg
We have still a couple issues with the PostGIS Driver
#94<http://trac.osgeo.org/fdo/ticket/94>
Generate extent for features assigned to default spatial context
We're going to check that one
#106<http://trac.osgeo.org/fdo/ticket/106>
PostGIS provider cannot delete a feature class
Deleting works with feature class and non feature class
But the table must be empty
#117<http://trac.osgeo.org/fdo/ticket/117>
PostGIS provider does not display attribute names in MapGuide when no PK present
This is a normal behavior
#171<http://trac.osgeo.org/fdo/ticket/171>
Fdo Postgis Autogenated identity property is mandatory
Not mandatory anymore
#178<http://trac.osgeo.org/fdo/ticket/178>
PostGIS : Can't insert in a non-feature class
Non-feature class works well with insert,delete,update and for displaying with join
232<http://trac.osgeo.org/fdo/ticket/232>
Fdo Postgis null and not null filter does not work
Not yet implemented, I will add this one in our unit tests
#233<http://trac.osgeo.org/fdo/ticket/233>
Fdo Postgis in and not in filter does not work
fixed
234<http://trac.osgeo.org/fdo/ticket/234>
Fdo Postgis currently does not support anything but lowercase identifiers
Still some pending problems with that one
#235<http://trac.osgeo.org/fdo/ticket/235>
Fdo Postgis Exception with insert
fixed
#236<http://trac.osgeo.org/fdo/ticket/236>
Fdo Postgis does not support non spatial classes
fixed
#241<http://trac.osgeo.org/fdo/ticket/241>
Implement Support for SelectAggregates, SpatialExtents and Count
Select Count works fine now, so selectAggregates also
Nothing was implemented
More testing should be done
Other things, there was a discussion with the community according to the class naming convention
So we have fallow the community recommendation and we have replaces the "shema~class" by "class" only.
We ran our test in different environments
100% FDO / C++ program ( without any map or Mapguide)
Map 2008 / fdo 3.2
Map 2009 / fdo 3.3
Mapguide 1.2 / fdo 3.2
Mapguide 2.0 / fdo 3.3
Using the same Postgres/PostGIS version as Matheus ( 8.2.4 + 1.2.1)
We have 3 primary spatial tables with all the same columns (one for point, one for line/multi-line and one for polygon/multi-polygon)
KEY_1 Int32
STRING_1 String
INT32_1 Int32
DOUBLE_1 Double
DATE_1 DateTime
STR_CODE_1 String 64
INT_CODE_1 Int32
GEOMETRY_1 GEOMETRY
plus one primary alpha table (without geometry)
and one primary X/Y table ( Postgis provider does not support displaying it YET)
We have one secondary alpha table for 1-1 joining ( KEY_1 = j_KEY_1) with the 5 primary tables
J_KEY_1 Int32
J_STRING_1 String
J_INT32_1 Int32
J_DOUBLE_1 Double
J_DATE_1 DateTime
J_STR_CODE_1 String
J_INT_CODE_1 Int32
We have two secondary alpha table for n-1 joining (INT_CODE_1 = INT_CODE_1 / STR_CODE_1 = STR_CODE_1) with the 5 primary tables
INT_CODE_1 Int32
DESC_1 String
And
STR_CODE_1 String
DESC_1 String
Unit test with FDO/C++ ( all test succeed, 0 failed)
Schema modification
Drop spatial table ( failed if data in the table)
Drop non-spatial table ( failed if data in the table)
Create spatial table
Create non-spatial table
All our test table are dropped and recreated using FDO prior doing any other test
Alpha Filter test
Using
FdoCommandType_Select (select column from ... )
FdoCommandType_SelectAggregates ( select Count(1) from ... )
FdoCommandType_SQLCommand ( complexe query with 1-1 / n-1 joins )
Key = 1
Key In (1,2)
Key Not In (1,2)
Key > 99
Key >= 99
Key < 2
Key <= 2
String = 'Bb'
String In ('Bb','Dd')
String Not In ('Bb','Dd')
String Like 'B%'
String Not Like 'B%'
Int = 10010
Int > 10990
Int >= 10990
Int < 10020
Int <= 10020
Double = 20010.0000001
Double > 118010.0097903
Double >= 118010.0097903
Double < 21010.0001
Double <= 21010.0001
Date = 2007-01-01
Date > 2007-04-09
Date >= 2007-04-09
Date < 2007-01-02
Date <= 2007-01-02
DateTime = 2007-01-01 00:00:00
DateTime > 2007-04-09 00:00:00
DateTime >= 2007-04-09 00:00:00
DateTime < 2007-01-02 00:00:00
DateTime <= 2007-01-02 00:00:00
Spatial Filter test
Using
FdoCommandType_SQLCommand ( complexe query with join )
geometry ENVELOPEINTERSECTS GeomFromText('POLYGON XY ...')"
geometry ENVELOPEINTERSECTS GeomFromText(POINT XY ...')"
we didn't test the LINESTRING ( we should )
Update test
Insert simple polygon
Insert multi polygon
Insert polygon with hole
Insert linestring
Insert multi linestring
Insert point
Insert alpha ( no geometry in table)
Delete polygon
Delete linestring
Delete point
Delete alpha ( no geometry in table)
Update int32 ( on spatial and non-spatial table)
Update String ( on spatial and non-spatial table)
Update double ( on spatial and non-spatial table)
Update date ( on spatial and non-spatial table)
Update datetime ( on spatial and non-spatial table)
Update geometry simple polygon
Update geometry multi polygon
Update geometry polygon with hole
Update geometry linestring
Update geometry multi linestring
Update geometry point
Test with Map 2008
Connecting OK
Attaching table with srid OK
Attaching table without srid -> map display a warning
Display point ok
Display linestring ok
Display polygon ok
Joining spatial table to non-spatial table ok
Table view display ok
Updating in the table view ok but the check-in crashes map
Check-out crashes map
Test with Map 2009
This after noon
Test with Mapguide 1.2
Everything seems ok
But still some testing to do with srid
Test with Mapguide 2.0
Everything seems ok
We are actually investigating on the crash problem within map 2008.
I don't know exactly what are the process to submit all our code changes with the release 3.2.2 and 3.3.0.
If you could provide some help on that point it will be appreciated.
Cheers
Bruno
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: jeudi 27 mars 2008 18:29
To: Bruno Scott (External)
Subject: FDO OSGeo PostGIS Provider
Hi Bruno,
I was wondering if you could provide an update on the status of the FDO OSGeo PostGIS Provider modifications that your team has been working on?
What changes have been made so far and how do these relate to the FDO Track issues that have been logged?
What is your plan to submit changes to the FDO OSGeo SVN?
When can your changes be rolled into our formalized build process and released as an official patch to the FDO 3.3 release?
Will you changes also support FDO 3.2?
If so, we need to get that the FDO 3.2 code dropped as well, and an official provider release posted.
Cheers,
Greg
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080404/9a937be0/attachment-0001.html
More information about the fdo-internals
