[fdo-internals] PostGIS and Spatial context question
Bruno Scott
bscott at geomapgis.com
Wed Apr 9 03:50:47 EDT 2008
Forgot something
Using Mapguide Studio 2009 it works ok
See Screen capture
http://www.nabble.com/file/p16581517/AddDataConnection.jpg
Bruno Scott wrote:
> PostGIS store its metadata in a table called geometry_columns
> For each of the spatialy enabled table we can specify a srid in this
> geometry_columns table.
> For PostGIS this srid is an integer that reference a coordinate system
> definition in a table called spatial_ref_sys.
> The actual implementation of the PostGIS provider that Matheus did, return
> something like
> PostGIS_SRID as spatial context ( where SRID is replaced by the proper
> srid integer )
> When i try to connect to PostGIS within Map2008 or Map2009, Map display an
> "Unknown" spatial context
> see screen capture
> http://www.nabble.com/file/p16581335/AddDataToMap.jpg
> Is it normal?
> How map is suppose to know how to translate a PostGIS srid to a Mentor
> one?
> Bruno
View this message in context: http://www.nabble.com/PostGIS-and-Spatial-context-question-tp16581335s18162p16581517.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals
