[fdo-internals] PostGIS and Spatial context question
Mateusz Loskot mateusz at loskot.net
Wed Apr 9 18:50:27 EDT 2008
Bruno Scott wrote:
> PostGIS store its metadata in a table called geometry_columns For
> each of the spatialy enabled table we can specify a srid in this
> geometry_columns table. For PostGIS this srid is an integer that
> reference a coordinate system definition in a table called
> spatial_ref_sys.
> The actual implementation of the PostGIS provider that Matheus did,
> return something like PostGIS_SRID as spatial context ( where SRID is
> replaced by the proper srid integer )
Bruno,
yes, that's right.
There is no concept like spatial reference system name in PostGIS, so
I decided to use that scheme to fill that gap.
> When i try to connect to PostGIS within Map2008 or Map2009, Map
> display an "Unknown" spatial context see screen capture
> http://www.nabble.com/file/p16581335/AddDataToMap.jpg
> Is it normal? How map is suppose to know how to translate a PostGIS
> srid to a Mentor one?
Name is just user level information. The engine and clients are supposed
to use WKT attached to every instance of spatial context.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
