[fdo-internals] Building scripts and dependencies
Jason Birch Jason.Birch at nanaimo.ca
Sat Apr 19 13:42:02 EDT 2008
Yeah, that makes sense.
If the documentation says it should work without explicitly including fdo, then either the build system should be changed, or the docs should be clarified.  I'd suggest the docs :)
Jason
Subject: Re: [fdo-internals] Building scripts and dependencies
Yes, it helps, but I'm not sure if it is expected behavior.
If it is, I think we should update the readme (?).
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080419/9025514b/attachment.bin
More information about the fdo-internals mailing list
