[fdo-internals] Before applying Bruno's patch
Greg Boone
greg.boone at autodesk.com
Mon Apr 21 10:30:16 EDT 2008
I have no issue submitting the path as long as you have recorded your comments and the projects build successfully.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Monday, April 21, 2008 10:01 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Before applying Bruno's patch
Folks,
I'd like to ask if there are any objections against applying Bruno's big
patch?
I'm about to finish reviewing it by reading & applying & building.
I'll not cover it with tests in 100% because the PostGIS provider unit
test suite is incomplete (my fault, sorry :-) ). So, I rely on tests run
by Bruno and his Team.
Is this acceptable? Can I submit?
Greetings
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
