[fdo-internals] boost_date_time dll is not part of the install
Jason Birch
Jason.Birch at nanaimo.ca
Mon Apr 21 11:09:59 EDT 2008
You're right; we still need to work on bundling the entire FDO release
in MGOS. I don't know what Autodesk plans to do around these providers;
I think if they distribute them they may feel an obligation to support
their clients using them :)
With the number of additional DLLs the client is required to install for
the PostGIS provider, I didn't really see a problem, but I understand
your point.
Jason
-----Original Message-----
Subject: [fdo-internals] boost_date_time dll is not part of the install
When we install Mapguide 2.0 and Map 2009
the only boost dll present is boost_thread-vc80-mt-1_34_1.dll.
the boost_date_time-vc80-mt-1_34_1.dll is not part of the install.
For a end user this dll is very difficult to find.
Adding this dll to the provider binaries is not a clean solution.
As Map 2009 is already shiiping, it is not possible to have this dll in
the
setup.
This is why i tough it was a simpler solution to remove this dependency.
Bruno Scott
More information about the fdo-internals
