[fdo-internals] Counting rows in managed IFeatureReader
Orest Halustchak
orest.halustchak at autodesk.com
Wed Apr 23 12:30:50 EDT 2008
Even with transactional support, you don't have a guarantee that two selects will return the same results unless the server supports a snapshot or serializable type of transaction isolation level, which is not usually default. Typical isolation levels are read-committed. But, this would be the same case regardless of whether you did a select aggregates and then a select versus running a select twice.
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, April 23, 2008 12:22 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Counting rows in managed IFeatureReader
Are there any concerns about the number of records changing between the
first SelectAggregates and the Select, or are all providers
transactional across a single session?
Jason
The 1st select should be a selectaggregate call using function Count()
where it is available. This will be optimized for most provider, will
avoid a full table scan and will limit the number of trip to the server.
The 2nd is to process those rows as needed.
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
