[fdo-internals] Counting rows in managed IFeatureReader
Orest Halustchak
orest.halustchak at autodesk.com
Wed Apr 23 13:02:21 EDT 2008
If the server supports a serializable isolation level, then you can rely on it, but that implies read locks being applied which can impact the operations of other users. Otherwise, in a multi-user update situation, there is always a possibility that data changes between selects. I think SQL Server supports a snapshot type of isolation that doesn't need read locks, but I'm not sure of the overhead of that option.
A question for Maksim for his application is why he needs the count before getting the data rather than knowing it after all the objects have been selected?
Thanks,
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, April 23, 2008 12:32 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Counting rows in managed IFeatureReader
So, there is no safe way of getting the count of features that are going
to be returned?
Jason
Even with transactional support, you don't have a guarantee that two
selects will return the same results unless the server supports a
snapshot or serializable type of transaction isolation level, which is
not usually default. Typical isolation levels are read-committed. But,
this would be the same case regardless of whether you did a select
aggregates and then a select versus running a select twice.
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
