[fdo-internals] RE: SDF feature reader
Gavin Cramer gavin.cramer at autodesk.com
Wed Aug 13 14:22:41 EDT 2008
Yes.  The particular problem that you are seeing can also happen with String values, since the pointer returned by GetString is to a buffer owned by the reader.  Per-connection threading for any provider (that supports this kind of threading, as determined by FdoIConnectionCapabilities::GetThreadCapability) is the way to go.
Gavin
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
Sent: Wednesday, August 13, 2008 2:18 PM
To: FDO Internals Mail List
Subject: [fdo-internals] RE: SDF feature reader
The SDF provider is per connection threaded which means only one thread can access a reader at a time. You can have many threads using their own connections/readers at the same time.
Badreddine
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, August 13, 2008 2:29 PM
Subject: [fdo-internals] SDF feature reader
I have issue when when more than one feature reader is created against same SDF connection
It looks like same buffer ( created by sqlite cursor ) is shared betwean feature readers.
This will cause that data returned from feature reader with function GetGeometry will be corrupted when another reader is used.
Is this a bug or I am not looking into it correctly ?
I would like to be able to use multi thread access to sqlite database.
If I am right, SDF provider is not "thread safe" ? if so, what are main reasons for  it ?
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080813/642c329f/attachment-0001.html
More information about the fdo-internals mailing list
