[fdo-internals] RE: SDF feature reader
Traian Stanev
traian.stanev at autodesk.com
Wed Aug 13 16:39:17 EDT 2008
Yes, this is an intentional limitation, for the same reason (performance).
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, August 13, 2008 4:53 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: SDF feature reader
Hm, but problem is not thread related.
Having 2 feature readers for same SDF connection inside one thread will create invalid data.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Wednesday, August 13, 2008 10:32 PM
This behavior is really a tradeoff between performance and full thread safety. SDF is near the performance end of the spectrum. I figure, if someone desires full
thread safety, they can use a real database.
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Gavin Cramer
Sent: Wednesday, August 13, 2008 4:27 PM
GetGeometry (the one returning an FdoByte *) has documentation that says the following:
"The array's memory area is only guaranteed to be valid until a call to ReadNext() or Close(), or the disposal of this reader object."
So, the code is behaving according to the specification. There should be a similar statement for GetString, as well as any other accessor that returns a pointer to non-reference-counted arrays, but I do not see one. Anyway, an FDO client should expect the above behaviour from any FDO provider, even if it actually does some internal copying.
Regardless, it looks like the behaviour that Haris sees is a defect. Different readers should not be sharing an internal cursor.
Gavin
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
Sent: Wednesday, August 13, 2008 4:14 PM
The free threaded provider would use FdoThreadCapability_MultiThreaded defined in https://svn.osgeo.org/fdo/trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h
The SDF provider is returning FdoThreadCapability_PerConnectionThreaded.
I had a quick look and I can see that the SDFSimpleFeatureReader::GetGeometry(FdoString*, FdoInt32*) is returing the pointer from the internal buffer. This may have been done to avoid paying the penalty of copying the geometry. The second oveload, GetGeometry(FdoString*) is returing a copy and should not have the same issue.
We may have to be extra carefull in case we decide to fix this issue to make sure the reader performance is not impacted.
Badreddine
Sent: Wednesday, August 13, 2008 3:12 PM
it looks that feature readers are sharing same sqlite cursor with one data buffer. (BTW: Application is sending this readers to be used by another app so it is not able to create new buffers)
Hm, you have lost me in this threading namings :)
Same SDF connection can't be shared across threads, right ? ( I thought that as thread safe )
I would like to understand reasons for that behavior and if there are rooms for improvements.
Sqlite connection can be shared between threads.
Thank you,
Haris
Sent: Wednesday, August 13, 2008 8:36 PM
It was not obvious that the readers were on the same thread. In that case it's a defect. Make sure to copy the geometry before ReadNext is called. It's possible the second reader(ReadNext) is invalidating the geometry.
The SDF provider is thread safe but not free threaded, it's per-connection threaded.
Badreddine
Sent: Wednesday, August 13, 2008 2:39 PM
I was saying for two feature readers inside same thread will result in error.
Also, i would like to understand why SDF provider is not thread safe.
Haris
Sent: Wednesday, August 13, 2008 8:18 PM
Subject: [fdo-internals] RE: SDF feature reader
The SDF provider is per connection threaded which means only one thread can access a reader at a time. You can have many threads using their own connections/readers at the same time.
Badreddine
Sent: Wednesday, August 13, 2008 2:29 PM
Subject: [fdo-internals] SDF feature reader
I have issue when when more than one feature reader is created against same SDF connection
It looks like same buffer ( created by sqlite cursor ) is shared betwean feature readers.
This will cause that data returned from feature reader with function GetGeometry will be corrupted when another reader is used.
Is this a bug or I am not looking into it correctly ?
I would like to be able to use multi thread access to sqlite database.
If I am right, SDF provider is not "thread safe" ? if so, what are main reasons for it ?
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080813/4d97638e/attachment.html
More information about the fdo-internals
