[fdo-internals] Standardising FDO Schema's
Zac Spitzer zac.spitzer at gmail.com
Fri Aug 29 22:54:02 EDT 2008
On Sat, Aug 30, 2008 at 5:08 AM, Robert Fortin
<robert.fortin at autodesk.com>wrote:
> As Orest said, FDO represents the data in different layer Datastore, Schema
> and Class. That's the rule.  That's the standard.
The fact that some provider doesn't have/require schema doesn't mean we
> don't need a generic schema representation in FDO.  It's up to the provider
> to say what this schema is named and what it maps to (e.g. default or
> something else). FDO doesn't impose rules around the name of the schema.
but currently there is no standard implementation pattern! that's the
problem!
which means every implementation can be different!
should a fdo client really care about which provider and data source is
being used?
Isn't FDO meant to flatten out all these differences...
In Orest's example with the oracle database, the database already exists,
with a well known
and understood access pattern right.  the database supports the use of
grants, synonyms,
roles etc. there is an existing structure in place.
create user denver identified by datamonkey
grant select on parcels.denver to denver.parcels
and so on
Isn't that a much easier and better place to be managing this kind of thing?
For example, removing the schema from SHP would result that you could have 2
> flavors of shp depending on the connection.  Connect to a single file and
> you get no schema.  Connect to a directory and you get a schema name
> "default".  SHP provider standardize to using "default" every time.
 Also applications relies on that standard: there will be a schema and it
> will have a name.  This result in consistant representation of the schemas
> and classes in a tree view for example. Changing this behavior has impacts
> on applications relying on that standard.
I agree the my suggestion of an empty schema would cause headaches, does FDO
have the concept of
a default schema? Ie GetDefaultSchema()? I just know fdo mostly from the
mapguide api side of things
standardising along these lines, primarily for databases providers, means
that any updating
to support this model would mostly involve removing custom provider specific
workarounds....
A lot of applications wouldn't be affected at all, they just pull whatever
structure the provider represents.
Those which do, probably have a lot of case statements to handle each
different provider's quirks,
which could potentially be deleted.
z
> Robert
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:
> fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Friday, August 29, 2008 11:05 AM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] Standardising FDO Schema's
> Orest Halustchak wrote:
> > The above is a logical schema. How could that be mapped to physical
> > schema? The discussion started with Oracle. Let's say I have an
> > Oracle instance called ORCL. The main physical grouping mechanism
> > that Oracle has is an Oracle Owner. So, one mapping is that the FDO
> > Data Store maps to Oracle Owner, then FDO Schema.Class maps to table.
> > That keeps the integrated set of data within a single Oracle owner.
> > Another mapping is to map FDO schema to Oracle Owner, i.e. define
> > Oracle owners LANDUSE, TRANSPORTATION, etc. But, then how do we
> > separate CityOfDenver parcels from CityOfBoulder parcels? I could
> > have DENVER_LANDUSE, BOULDER_LANDUSE, etc. There is a third mapping
> > possible, and that's to use a separate Oracle instance for each data
> > store, but users may not want to set up separate physical instances
> > for this purpose, especially if they have a large number of data
> > stores.
> Orest,
> Thanks for the very in-depth explanation of schema naming issues.
> But we still need a consistent way to define and describe all
> possibilities of mapping and naming paths in text.
> As Zac proves, using only separators (like ::, ~, etc.) is insufficient.
> I think more self-describing approach is needed, perhaps we would use
> XML or JSON for naming schemas?
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080830/1f9a5f72/attachment-0001.html
More information about the fdo-internals mailing list
