[fdo-internals] Fw: MapGuideJavaApi.dll
Greg Boone
greg.boone at autodesk.com
Fri Jan 25 12:48:33 EST 2008
Hi Luiz,
I believe this is a mapguide issue rather than an fdo issue. You should re-post this question to the mapguide internals email alias.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Luiz Marcio Viana
Sent: Friday, January 18, 2008 2:14 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Fw: MapGuideJavaApi.dll
I'm studing the MapAgent functionality and the API support and I have
verified which some methodes are not exposed to the API.
I wan't to add some of these methodes in my enviroment but the API is
generated automaticly.
First the MapGuideApi.i file is created and after the DotNet, PHP and Java
code is generated.
What is the procedure to add methodes in the MapGuideApi.i.
Thanks,
Luiz Marcio
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
