[fdo-internals] RFC 20 for review
Orest Halustchak
orest.halustchak at autodesk.com
Tue Jul 15 09:34:07 EDT 2008
I haven't heard any response - do folks think it's worth pursuing this. If it's worthwhile in principle but need to fix the details or not worthwhile?
Thanks,
Orest.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: Thursday, July 10, 2008 1:27 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RFC 20 for review
Getting back to the general discussion, and trying to step back a bit, there are definitely trade-offs here.
Pros:
* Easier to define new capabilities: Instead of having a new function every time we want to advertise a new capability, we can use a generic function and not have to change the fdo api.
* Providers can be updated over time rather than all having to be recompiled with a new version of the fdo api.
* A small set of functions to call to discover all of a provider's capabilities.
Cons:
* Too easy for providers to start defining their own very provider specific capabilities. Perhaps for the osgeo providers we can control this because we should still have RFC process, but we can't control commercial providers. This is the concern that a few of you have raised. It's too easy to break the concept of generic capabilities.
* Developer has to know the return type to use the correct generic function to get a capability value.
Maybe there are more pros and cons, but these are some of the main ones.
Also, this mostly helps cases where we need to advertise a new capability that doesn't require other api changes. For instance, if we add a whole set of new functions around network handling, we are changing the api anyway, so the benefits aren't really there as much. But, if we discover that for existing functions, we're hitting an issue with different behavior that should be advertised, e.g. providers A, B, and C support geometry curve types, but providers B and C only support them for non-lat/long systems, we're not adding new functions, just a more detailed capabilities response. Once the PSC agrees on the capability, it can be added without a new version of the fdo api. The current approach would need to define a new function somewhere which implies a new fdo api version - recompile all providers, etc.
If we feel that the benefit does not outweigh the costs, then we shouldn't bother with it.
I hope this helps clarify things.
Thanks,
Orest.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Thursday, July 10, 2008 12:57 PM
Yes, I was trying to imagine how versions would work.
Thanks Robert :)
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Fortin
Sent: Thursday, July 10, 2008 5:09 PM
Without speaking for Harris, I think Haris is discussing the impact of the suggested API vs the provider/FDO version number when a new capability is added at FDO level. The new API would not require the a FDO version upgrade which is now the case everytime we add a single new capability.
RF
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Thursday, July 10, 2008 9:56 AM
[Haris] We would say it is FDO 3.4.1 because one provider have new capability ? I think FDO capabilities "belongs" to FDO not to providers.
I'm confused. On one hand you suggest that we shouldn't rebuild FDO when one provider is adding a new capability. On the other hand, I cannot see how a new capability "belongs" to FDO without rebuilding FDO.
Could you please elaborate?
Thanks,
Dan.
Sent: Wednesday, July 09, 2008 3:56 PM
I agree that we don't want provider specific capabilities, that capabilities need to be specified in a generic way. I agree with Haris' statement that capabilities belong to fdo and not to providers.
But, is there a way to simplify the process of adding new capabilities (after agreeing that a new capability is needed and can be defined in a generic way)? Instead of adding a new function each time, if we have a generic, smaller, set of functions, new capabilities can be defined without changing the api. Providers can be updated over time as opposed to requiring all providers to be updated right away. It seems that a side effect of trying to achieve this goal opens the possibility of individual provider specific capabilities, but that isn't the intention. The intention is to have some robustness so that if a newly defined capability is handled by one provider, using another provider that hasn't been updated yet won't break the application. An application can start taking advantage of a new capability without waiting for all providers to be updated to the new api.
There was an email thread a while ago I believe expressing concern about the complexity of all the capabilities functions and having to add new functions each time. It seems that if we want to do this, we should try to deal with it soon or decide that we'll just live with the current approach. There are pros/cons to each. Are there other approaches/ideas?
Thanks,
Orest.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, July 09, 2008 3:34 PM
I have to say that this was also my initial impression of the RFC, and to some extent the RDBMS vs file distinction in RFC23. They serve to reduce the homogeneity of FDO, which in turn makes building applications based on FDO more difficult.
I am concerned that this mechanism could be used to add new capabilities to individual providers without considering whether these capabilities would be better in a more generic form, or how applying them to a single provider could affect other providers in the future. If this does go through, it would be important to make it clear that adding a new capability to a provider would not be excluded from the RFC process.
The more divergent the individual providers become, the less easy it is to write an application that works with all providers. Reducing the cost of maintaining the core library at a consistent level results in this cost being passed along exponentially to all clients that have to manage inconsistencies between the providers. I understand that there is some pain keeping the providers in sync, but that's the price of an abstract framework. Maybe this is not a good way of looking at it, but my feeling is that ff certain providers can't be upgraded with new functionality, then they will just get left behind until the community recognises the need to upgrade them to the latest version of FDO and applies resources to get them caught up.
In my view, new capabilities should only be added when they are absolutely required and after serious consideration. In some ways, this cost is a good thing, as it slows the rate of change in the framework.
Jason
Sent: Wednesday, July 09, 2008 11:53
Hi Tomass,
thanks for answers.
I am very uncomfortable with this RFC. Perhaps I don't understand it well enough so I will ask many questions and try to understand motivation for it.
In your previous answer you said that motivation is to not rebuild FDO and providers because of one provider change.
I think I understand your answer and motivation as it is written in RFC but my concern was that doing that is not right thing.
My main concern is that this RFC goes against one of the key values of FDO: access different spatial data formats with one unified interface.
I think unified and clear access to different data stores is far more important than "fast" adding of new capability for one particular provider.
I see this RFC as a path to start to write applications which are tied to particular providers.
I would like to understand use case of it and would try to ask with example.
If I see it correctly use case of this would be that we have application build against let say FDO 3.4. Then we would like to add new capability to e.g. SDF provider and then use that new capability in new build of application with same "old" FDO 3.4 but with new version of provider .
Does this implies that we could have different flavors of FDO 3.4 or it would be 3.4.1 but just no need to add capability to other providers? We would say it is FDO 3.4.1 because one provider have new capability ?
As of discussion about new capabilities enumerators not coded anywhere or use of strings. I also feel like it is wrong.
How we would share those enumerations or strings between providers ? It could end up that because some new capability is not supported in all providers at same time that it will have different number in different providers ? Having some list (or few of them) of codes for capabilities sounds very odd too me.
As of error handling: same result ("isUnknown" to true ) would be for non existing capability as well as for wrong type of it ?
Again sounds like we could end up with different type reported from different providers for same capability.
When writing FDO client application It would be wrong if we would need to check at different lists to find codes for same capability and to check it against all providers.
You mentioned : "certain unique mechanism in place to avoid duplication". This is yet to decide ?
Sorry if I am little hard or long but this RFC seems very important to me.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Thomas Knoell
Sent: Wednesday, July 09, 2008 7:20 PM
Hi Harris,
Thanks for the comments.
As for the motivation, currently there is no way to add a new capability to FDO without the need to implement that new capability in all providers that want to use the updated FDO code base. The new interface concept provides the chance to actually do this as capabilities can be added without changing FDO. As a result, only the provider that wants to support the new capability needs to implement the support.
As for the error handling, this is documented in RFC 20. If a user calls a function - for example GetBooleanCapability for a capability that returns an Int32 - the function would set the flag "isUnknown" to true. It is up to the caller to check this flag an react accordingly. For example, the caller could either use a default value that is appropriate in this case or throw an exception. But this is all up to the caller.
Thanks
Thomas
Sent: Tuesday, July 08, 2008 7:45 PM
I think this is much more complicated way of exposing capabilities rather than like it says in RFC simplifying.
I am not sure about motivation for it. For example If application is build with newer version of FDO core I would think that older provider will not be used anyhow .
I can't see reasons when application which is build for use with one version of FDO libraries will use older providers.
Also Isn't it going to be a problem when application is linked with one version of FDO core libraries and provider is like build with another. With current dll naming it is not possible I think ?
I couldn't find in RFC error handling for case when function of wrong type of capability is executed for existing capability ( e.g. Call GetBooleanCapability for Int32 ) ?
Haris
Sent: Tuesday, July 08, 2008 11:38 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] RFC 20 for review
RFC 20 (http://trac.osgeo.org/fdo/wiki/FDORfc20) has been posted. It proposes a simplification of the FDO capability interfaces. Please review the RFC and let me know of any questions and suggestions you may have. The review deadline is set for end of day July 18th. It is intended to request a vote on the RFC afterwards.
Thanks
Thomas
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080715/25d544dd/attachment-0001.html
More information about the fdo-internals
