[fdo-internals] SDF 3.0 FDO Provider Serious Memory Leak
Greg Boone
greg.boone at autodesk.com
Thu Jul 17 10:37:10 EDT 2008
Hi Maksim,
The 3.4.0 binaries are built using VS 2008. You probably are missing the required MS runtime DLLs. Run Depends.exe on FDO.dll to figure out the missing dependencies.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Thursday, July 17, 2008 3:53 AM
To: 'FDO Internals Mail List'
Subject: RE: [fdo-internals] SDF 3.0 FDO Provider Serious Memory Leak
Hi Greg,
I just had trouble updating previous application release based on FDO 3.3.1
with new build. I guess there are some newly introduced dependencies,
boost_date_time-vc90-mt-1_34_1.dll and boost_thread-vc90-mt-1_34_1.dll (or
Xalan/Xerces) come to mind. That is, I need to fix installation setup
prerequisites to include something needed by new FDO build to work properly
on target machine. Is it some newer Microsoft C/C++ Runtime Library?
Regards,
Maksim Sestic
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, July 16, 2008 16:00
To: FDO Internals Mail List
Yes. The files and binary version identifiers have yet to be moved to use
the new 3.4.0 version numbers. I will track it and see that is gets done.
Greg
Sent: Wednesday, July 16, 2008 3:59 AM
Hi Greg,
Nothing important, just check out the archive name (3.3.0 instead of 3.4.0)
since it can be misleading for someone stumbling onto it :-)
Regards,
Maksim Sestic
Sent: Tuesday, July 15, 2008 17:03
The last weekly 3.4.0 build has been posted to:
http://download.osgeo.org/fdo/3.4.0/unofficial/weekly/G12/
Greg
Sent: Tuesday, July 15, 2008 10:09 AM
I will post the unofficial 3.4.0 weekly build for download.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Carl Jokl
Sent: Tuesday, July 15, 2008 3:05 AM
To: fdo-internals at lists.osgeo.org
Is version 3.4 available for Download? I have only found downloads available
up to version 3.3 in terms of precompiled downloads. Would it require
building from the latests source instead?
View this message in context:
http://www.nabble.com/SDF-3.0-FDO-Provider-Serious-Memory-Leak-tp18447913p18
458622.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
__________ NOD32 3269 (20080715) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
__________ NOD32 3272 (20080716) Information __________
http://www.eset.com
More information about the fdo-internals
