[fdo-internals] RE:RE: Property2ColNameChar
    Orest Halustchak
    orest.halustchak at autodesk.com
    Wed Jun 11 12:21:53 EDT 2008
We had an earlier email thread on this. I think index access would be beneficial in improving this access which happens over and over for every property and every object on a select.
Anybody want to write an RFC?
Thanks,
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, June 11, 2008 12:22 PM
To: FDO Internals Mail List
Subject: [fdo-internals] RE:RE: Property2ColNameChar
Perhaps I don't understand you correctly but I don't see need for
internal mapping. For most database clients access we need to use index
to access it. Usually it is done vice versa , needs to map column name
to index of data which have been retrieved from database.
I also don't quite understand char-wchar.
If FDO provider creates list of properties in same order which is
returned by database client software I don't see any need for mapping (
even if FDO provider decides to change it then it would be number-number
mapping ).
I think for most type of applications MapGuide or others, index access
of FDO class property would be faster way to go.
Same way, if I write non-FDO application to access repeatedly e.g.
Oracle data, I would use index to access property not an column name.
Having access via column name is functionality good to have.
I think , we would need to have index access too, where index
corresponds to index in FDO class property list.
And then general applications like MapGuide would use index access not
column name access to FDO class properties.
Haris
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Wednesday, June 11, 2008 5:51 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] RE: Property2ColNameChar
> we are missing "stanadard" index access to properties and than
application can decide which one to use.
Even so, the provider has to keep an internal mapping because the index
of the property doesn't necessary match the index of the corresponding
column (e.g. RevisionNumber column).
Besides, doing everything under the hood has another advantage: it saves
the conversion from wchar to char (usually needed when going from
logical to physical) by caching the char value as well.
Dan.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, June 11, 2008 11:15 AM
Subject: [fdo-users] RE: Property2ColNameChar
I have looked at the code of Property2ColNameChar and few questions pop
up.
I believe when I was developing King.Oracle I was posting that we would
need to have index access to properties, simillar as database client
APIs have. I am not sure but I would be suprised if other database
access software have implemented such mechanisems on data access level.
To me , It looks like that we are missing "stanadard" index access to
properties and than application can decide which one to use.
Haris
Sent: Wednesday, June 11, 2008 4:23 PM
Subject: RE: [fdo-users] PostGIS FDO Provider performance issues
My bet is that "something else" is the look up for the property in the
logical/physical collections of properties.
E.g. for 20 properties in the class the provider will do aprox.
2,000,000 wide string comparisons for 200,000 rows.
Actually it is 4 million because of IsNull() calls. This is the
performance killer.
The problem has been solved for rdbms providers by caching the
properties in the order they are fetched (at the first fetch). So the
property will be found either in the same position (after a IsNull) or
in the next slot. This is equivalent to fetching a property by index
rather by name.
The implementation is in GenericRdbms:
FdoRdbmsFeatureReader::Property2ColNameChar()
Hope this helps,
Dan.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, June 11, 2008 3:03 AM
Subject: Re: [fdo-users] PostGIS FDO Provider performance issues
I would agree it's too much overhead, as this happening with Oracle as
well ( anyone else seen
this happen with another db?) perhaps there is something else in play.
How many rows are fetched by the client? Fetching one row at a time is
slower than returning blocks of 100 rows..
Using mapguide, it's always the mapguide process (ie FDO) and not the
database which is showing the high cpu
z
On Wed, Jun 11, 2008 at 4:56 PM, Carl Jokl <carl.jokl at keynetix.com>
wrote:
> It is true that there is extra overhead in performing the conversion
or going
> through FDO but I think it is fair to say that having PostGIS 16 to 20
times
> slower on the same data is more of a performance hit than would have
been
> expected.
http://www.nabble.com/PostGIS-FDO-Provider-performance-issues-tp17756475
p17771210.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
