[fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Mateusz Loskot mateusz at loskot.net
Tue Mar 18 16:48:29 EDT 2008
Mateusz Loskot wrote:
> Jason Birch wrote:
>> - Although I like the FGF format, I'd be worried that embedding it as
>> blob data would close the format.  OGR has an interesting convention for
>> using WKT columns with SQLite.  It would be nice if the FDO provider
>> could support that approach in addition to the default approach, and
>> maybe WKB too?:
>>    http://www.gdal.org/ogr/drv_sqlite.html
> WKB is not sufficient for that purpose. What is needed here is so called
> "spatial native format" similar to EWKB (EWKT), binary format used
> natively in MySQL. I think, WKT is out of consideration due to
> performance weakness of analysing plain text data.
I've discussed with Frank about FGF vs WKB/WKT and I think I owe some
clarifications.
My positions are:
1. If we focus only on implementation of the FDO Provider for SQLite,
then I think that FGF is a better choice than WKT/WKB because it will
not require FGF<->WKB translations. Format translations are potential
performance bottlenecks.
2. If we came to the conclusion that it's better to implement more
universal solution, then WKB format is reasonable choice.
Potentially, there is a chance for development of universal solution
without loosing max of performance. The option is to follow OGC SFS and
common implementations like PostGIS or MySQL. Simply, we should be able
to extend SQLite with OGC SFS functions: AsBinary and AsText
Then, following schemes would be possible:
1. Return FGF as native format, equivalent to PostGIS EWKB
SELECT the_geom FROM table:
2. Request WKB
SELECT AsBinary(the_geom) FROM table;
3. Request WKT
SELECT AsText(the_geom) FROM table;
Following this concept, it could be even possible to implement AsEWKT
and AsEWKB to gain some level of compatibility with PostGIS.
Why I'm saying such option is possible?
 From version 3.3.6, SQLite supports loadable extension modules
providing additional SQL functions:
http://www.sqlite.org/cvstrac/wiki?p=LoadableExtensions
"Additional functions may be written in C and added to the database
engine using the sqlite3_create_function() API."
http://www.sqlite.org/lang_expr.html
http://sqlite.org/capi3ref.html#sqlite3_create_function
Short example about creating custom functions:
http://souptonuts.sourceforge.net/readme_sqlite_tutorial.html
http://souptonuts.sourceforge.net/code/myfuncpp.cc.html
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
