[fdo-internals] CODE SUBMISSION -- Ticket #249 : Support PREFIX make build variable on Linux
Greg Boone greg.boone at autodesk.com
Thu Mar 20 15:54:18 EDT 2008
Author:           Greg Boone
Date:             Thursday, March 20, 2008
Title:            Support custom Linux install location for FDO
Reviewed by:      TBD (Jack Lee)
Abstract
This submission modifies the FDO build scripts for Linux to allow FDO to be installed in a user specified directory location. Previously, the FDO build-install-runtime process expected FDO to be located in /usr/local/fdo-3.3.0.
to build FDO and install it to a user-specified location, you may build FDO in the following manner:
     ./build_linux.sh --p <custom install location>
e.g.
     ./build_linux.sh --p /usr/fdo
OR.. a user may bypass the FDO build_linux.sh script and directly call...
      aclocal
      libtoolize --force
      automake --add-missing --copy
      autoconf
      ./configure --prefix=/usr/fdo
      make
      make install
If a custom installation is not specified the default install location will remain /usr/local/fdo-3.3.0
If a user-specified installation location is used, application are REQUIRED to set an environment variable, FDOHOME, identifying the new location directory so that the providers.xml file may be correctly found and loaded.
e.g.
    export FDOHOME=/usr/fdo
TESTING PERFORMED:
<Minimum of regress>
Note to Developers
NONE
Bugfixes
Module by Module
trunk/build_linux.sh
trunk/build_thirdparty.sh
trunk/providers.xml
trunk/Fdo/Unmanaged/Src/Fdo/ClientServices/RegistryUtility.cpp
trunk/Providers/WFS/build_linux.sh
trunk/Providers/GenericRdbms/build_linux.sh
trunk/Providers/WMS/build_linux.sh
trunk/Providers/SDF/build_linux.sh
trunk/Providers/SHP/build_linux.sh
trunk/Providers/KingOracle/build_linux.sh
trunk/Providers/PostGIS/build_linux.sh
trunk/Providers/OGR/build_linux.sh
trunk/Providers/ArcSDE/build_linux.sh
trunk/Providers/GDAL/build_linux.sh
/Providers/GenericRdbms/Docs/Makefile.am
Components Affected <== Identify all components that will need recompilation
Linux Build Process
Reviewers' Assessment
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080320/f6809887/attachment-0001.html
More information about the fdo-internals mailing list
