[fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Jason Birch Jason.Birch at nanaimo.ca
Sun Mar 23 18:36:00 EDT 2008
Any chance that I could convince you guys to use "geometry_type" (or something else) rather than "type" in the table definition?  Using a generic term like "type" is just bad karma from a database design standpoint...
If you did this, would you feel the need to go to the integer definition for this field and use the numeric codes in the spec?  And is there a strong reason for deviating from this, other than not supporting all of the types?
Jason
Subject: RE: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
Hi Frank,
No problem, feel free to post the file (it came from publically available data).
Since I sent you that file, I have also added support for the geometry_columns (and spatial_ref_sys) in my code. I had the same columns as you have in the RFC, except for the "type" column. I will adjust the code to support "type" as well.
More information about the fdo-internals mailing list
