[fdo-internals] FDO documentation questions
Haris Kurtagic
haris at sl-king.com
Thu May 1 13:24:25 EDT 2008
King.Oracle is supporting batch insert. I remember testing it in Fdo2Fdo
when it makes a speed difference when copying data.
I will look into Fdo2Fdo code and give you and example.
Haris
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Donald
Cameron
Sent: Thursday, May 01, 2008 3:59 PM
To: 'fdo-internals at lists.osgeo.org'
Subject: [fdo-internals] FDO documentation questions
I am working on the FDO documentation: The Essential FDO, The FDO
Developers Guide, and the FDO API Reference.
I was going to write some sample code that does batch inserts using the
OSGeo.FDO.Commands.BatchParameterValueCollection property of the
OSGeo.FDO.Commands.Feature.IInsert command but I was told that no
providers support batch insertion.
I currently believe that the SupportsParameters() method of
OSGeo.FDO.Connections.Capabilities.ICommandCapabilities says whether a
provider supports batch inserts.
According to a program I wrote, three providers support parameters:
ArcSDE, KingOracle, and PostGIS.
So my question is this: Do they actually support batch insertion?
If so, I would be very grateful for some sample code showing how to use
BatchParameterValueCollection to do batch insertion.
Regards,
Don
Don Cameron
Autodesk Inc.
Developer Publications Specialist
Ottawa, Ontario, Canada
613.233.3758
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.7/1408 - Release Date:
4/30/2008 6:10 PM
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20080501/4c1acf48/attachment.html
More information about the fdo-internals
