[fdo-internals] MySQL Defect with Count(1)
Bruno Scott
bscott at geomapgis.com
Mon May 5 02:55:38 EDT 2008
Hi Dan, we have a huge application that does a lot of database stuff.
We use Count(1) on any database just to know how many record we are going to
process.
Count(1) works on any databse(access,sqlserver,oracle,postgres,mysql...)
Using Count(1) is easier than passing a column name.
Dan Stoica wrote:
> Hi Bruno,
> Quick question: why do you need Count(1)? For performance perhaps?
> Thanks,
> Dan.
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Tuesday, April 29, 2008 2:37 AM
> To: fdo-internals at lists.osgeo.org
> Subject: Re: [fdo-internals] MySQL Defect with Count(1)
> By the way i have found the same piece of code in the sqlserver provider
> Bruno Scott wrote:
>> I just found and enter a ticket about this one.
>> I've been a little further.
>> Select Count(1) failes with "Unsupported FDO type in expression"
>> It was working ok in release 3.2
>> I think i have found were the problem is.
>> ProcessAggregateFunction has been overridden in release 3.3 ( to handle
>> ALL and distinct i guess)
>> extract of ProcessAggregateFunction function
>> if (dataValue->GetDataType() == FdoDataType_String)
>> // Omit ALL if specified as this keyword is not supported
>> in
>> // MySQL.
>> else
>> throw FdoFilterException::Create(NlsMsgGet(FDORDBMS_29,
>> "Unsupported FDO type in expression"));
>> As 1 is not a string -> boom
>> I have tried with
>> Select Count('1') and it works fine
> http://www.nabble.com/MySQL-Defect-with-Count%281%29-tp16939555p16953704.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/MySQL-Defect-with-Count%281%29-tp16939555p17053950.html
More information about the fdo-internals
