[fdo-internals] PATCH: OGR provider fixed to use FDO spatial
test, rather than GEOS
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat May 17 11:07:06 EDT 2008
No problem, I will do that for future patches.
If that procedure is considered the standard, someone should update the
instructions page:
https://trac.osgeo.org/fdo/wiki/SubmitPatch
I have created a trac issue, and attached the patch:
https://trac.osgeo.org/fdo/ticket/343
Regards, Kenneth Skovhede, GEOGRAF A/S
Mateusz Loskot skrev:
> On May 17, 2008, at 1:35 PM, Kenneth Skovhede, GEOGRAF A/S wrote:
>> Attached is a diff agains the trunk version of the OGR provider.
>> It all works in my tests, but I would appreciate it if someone would
>> review the changes to see that there are no unintentional memory
>> leaks, or places where there should be a copy rather than a reference.
> Kenneth,
> Thanks for the patch. If you don't mind, I'd like to encourage you to
> submit patches by creating a new ticket and attaching patch file on
> the FDO Trac at http://trac.osgeo.org/fdo/
> Thanks!
More information about the fdo-internals
