[fdo-internals] PostGIS Defect : provider does not support views
Bruno Scott
bscott at geomapgis.com
Fri May 30 11:03:39 EDT 2008
If you have a view defined in postgis, you can not use it as the provider
does not list it in available featureclass or class.
To make it available as a feature class would have to manually insert a
record for the view in the geometry_columns table.
I have created a ticket for it
Bruno
View this message in context: http://www.nabble.com/PostGIS-Defect-%3A-provider-does-not-support-views-tp17561194p17561194.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
