[fdo-internals] Request review of RFC 28
-AddStart/EndExpressionFunctions
Dan Stoica
dan.stoica at autodesk.com
Tue Nov 4 13:17:47 EST 2008
The trouble is these functions must return doubles. On the other hand we already have the MBR functionality.
Dan.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, November 04, 2008 11:52 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Request review of RFC 28 -AddStart/EndExpressionFunctions
Then how about just a BBOX() function - for points it would obviously return the coordinates of the point, so it would work for the purpose we need. For other geometries, it would return the MBR.
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Tuesday, November 04, 2008 11:46 AM
How about a variation on PointX(), etc.
MidX(geom)
MidY(geom)
MidZ(geom)
Where the Mid is the center of the extents. It would make sense for all geometry types and useful (say) to place a label.
Not related to the above but to throwing exceptions: the reader has to handle the NULL geometries anyways. So the unsupported types can be handled the same.
Regards,
Dan.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
Sent: Tuesday, November 04, 2008 11:27 AM
A different approach is to create functions which takes a geometry and an enumeration, this way each provider can implement all cases or just a few of them, e.g.:
PointX(geom, enum)
PointY(geom, enum)
PointZ(geom, enum)
Where enum can be: 'start', 'end', 'min', 'max', 'centroid', ...
For now we may implement just a few of them (start, end) and in the future we could implement more cases.
Romy.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Tuesday, November 04, 2008 10:28 AM
To: 'FDO Internals Mail List'
Hi Orest,
I agree, but I presume these functions will get implemented out of necessity - i.e. original RFC author definately had something in mind while suggesting PointX/Y or StartX/Y functions... and it's probably tied to labeling (Map, MapGuide). If this is the case, then functions can get adopted to fit that specific purpose. I agree it's a slippery slope there, easily slipping to stylization issues etc :-)
Regards,
Maksim Sestic
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: Tuesday, November 04, 2008 16:00
Maksim, these are good ideas, and there are all kinds of geometry type functions that we could add such as your AngleXY() example - centroid, mbr, buffer, etc. We already have length and area.
However, the purpose of this RFC is for a basic set of functions to help with displaying coordinate values in a data table type report, so expanding it to a lot of other things would be beyond the scope of what we wanted to build at this time. I think if folks find these other functions useful (and I agree that they are useful), my suggestion is to create a new RFC for them.
For the simple point function, it looks like we have the following ideas (extrapolating a bit from the discussion):
* StartX(geom), StartY(geom), etc.
* PointX(geom), PointY(geom), etc.
* PointX(geom, n), PointY(geom, n), etc.
* MinX(geom), MinY(geom), MaxX(geom), etc.
* CentroidX(geom), CentroidY(geom)
The startx/endx type functions have issues related to what they mean for polygons and multi-type geometries. They make sense for line and point geometries. For a single polygon loop, they sort of make sense.
The pointx/pointy type functions are fine for points, but don't have meaning for other geometries unless we treat them as centroid. I'd rather avoid defining functions that throw exceptions for a large number of geometry types if we can. My preference would be to have a defined result for all geometry types if at all possible.
The pointx(n) type functions are more useful in general that starx/endx type functions, but have the same issue around what they mean for polygons and multi-type geometries.
The minx/miny type functions work for all geometry types, but require extra processing than just grabbing an existing point form the geometry object.
The centroidx/centroidy type functions also work for all geometry types, but also require extra processing.
Orest.
Sent: Tuesday, November 04, 2008 3:08 AM
Subject: RE: [fdo-internals] Request review of RFC 28 - AddStart/EndExpressionFunctions
Why don't you introduce optional parameter for vertice index being inspected, i.e. PointX(n) - if there's no parameter then value of 0 is assumed (used with Point geometries). In that way one can evaluate linestring and polygon single vertice coordinate.
I think there's something else missing - I'm trying to draw directions for one-way roads, as in Google Earth/Map. Although each road network's linestring is directed (as in directed graph) and has direction flag attached (uni/bi-directional), I still don't have enough data to actually rotate an arrow - depicting road direction. How about introducing AngleXY() and AngleXY(n) functions returning line segment angle in plane? Is there any other solution to this, except for storing pre-calculated vectors? Maybe adding some additional stylization rule for this?
Regards,
Maksim Sestic
Sent: Monday, November 03, 2008 23:40
Yeah, may be just provide PointX()/PointY()/PointZ() functions which take a geometry as argument and throw an error for anything but points?
Traian
Sent: Monday, November 03, 2008 5:24 PM
Subject: RE: [fdo-internals] Request review of RFC 28 - Add Start/EndExpressionFunctions
What has the Start point so special except for the point features? For example, the START=END for simple polygons.
Maybe this ECO should address only points?
Dan.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Monday, November 03, 2008 2:53 PM
Yes, Lines and Polygons do offer some difficulties. Also, the multi-geometry objects are also a little weird. I am open to suggestions on how to handle these types.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, October 23, 2008 12:34 PM
That makes sense to me; I just wasn't sure what you would use the equivalent function for lines/polygons for.
Jason
The use case: presents the ordinates of a point geometry as attribute in a data table. This feature will help us achieve that.
You could also think it can be used to display the coordinate as labels as part of the symbology of a feature.
Or you could use the StartZ to show the elevation of a point or apply a theme on it.
All these can't be done easily directly using the geometry attribute.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3580 (20081103) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3582 (20081104) __________
http://www.eset.com
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081104/8a7f6776/attachment-0001.html
More information about the fdo-internals
