[fdo-internals] RE: FDO Function SpatialExtents
Haris Kurtagic haris at sl-king.com
Tue Nov 18 16:20:16 EST 2008
Perhaps I understand you now :)
SDO_ROOT_MBR is not even close to layer extent for geodetic CS.
Any clue how Autodesk.Oracle provider is calculating index extent from that SDO_ROOT_MBR  for geodetic CS?
Rhank you,
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Tuesday, November 18, 2008 5:28 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: FDO Function SpatialExtents
Ø  It will not return exact extents of geometries but will return what is written in index meatada (SDO_ROOT_MBR from sdo_index_metadata).
Harris, as I said before, watch out for geodetic coordinate systems.
Dan.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Tuesday, November 18, 2008 10:29 AM
I have implemented in King.Oracle special case of SpatialExtents for all geometries in class.
If there is filter set with SelectAggregate command then correct extent will be returned ( using SDO_AGR_MBR Oracle function ).
I have implemented in such way because MAP 3D is using SpatialExtents every time when layer is to be displayed and because of that rendering in MAP becomes slow.
I think it is not correct that SpatialExtent will not return exact MBR but because MAP 3D is obviously very important FDO client priorities are reordered :)
I would suggest ( RFC ? ) that we would have dedicated commands/functions which are used in typical applications.
-          command to return just "zoom extent" of layer
-          command to get geometries and keys from window query (envelope intersect)
-          command to get selection based on rectangular window
-          few more...
Right now providers are parsing select command and try to discover those special cases which are basically not special cases but standard cases coming from practical use.
Haris
Sent: Tuesday, November 18, 2008 12:47 AM
I think it is very important question.
Autodesk Oracle provider is not returning correct result if (and I think it is) SpatialExtent is supposed to return exact MBR of geometries.
I am looking now at SqlSrever provider and there are 2 special cases for Count and SpatialEXtents for whole layer.
For those 2 special cases there is special code and special OptimizedAggregateReader etc...
What looks wrong to me is that we used exact SpatialExtent function to return something what doesn't need to be exact.
Shouldn't be better to have special command or special function to return count, extents of layer etc..
Now it looks to me that code of provider is more complicated and also we have function which could or could not return expected result.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, November 18, 2008 12:17 AM
It's a question of practicality, not belief. J
SpatialExtents exists only so that providers which can provide a faster implementation than the naïve iteration over all features can make that feature accessible. If you want to provide the naïve implementation of iterating over all features and computing the union of their MBRs, then save yourself the effort, since Map already has this fallback.
Traian
Sent: Monday, November 17, 2008 6:34 PM
Traian,
Now I don't understand you :)
I would believe SpatialExtents should return exact MBR value of geometries in Select query.
Haris
Sent: Tuesday, November 18, 2008 12:04 AM
To: 'FDO Internals Mail List'
Theoretically it has to return the MBR of its argument.
In practice, it doesn't need to be exact, since the code that uses it does not need it to be exact.
You don't have a choice anyway, if you want it to perform at all...
Traian
Sent: Monday, November 17, 2008 6:22 PM
Hm, but what is SpatialExtent function, exact MBR or not ?
Haris
Sent: Monday, November 17, 2008 11:54 PM
Yes, just return the bounding box of all the geometries. Map does not need exact BBOX, just an extent it can zoom to in order to show something once you add the layer.
Traian
Sent: Monday, November 17, 2008 6:16 PM
Yes, SDO_AGGR_MBR could be slow.
In Oracle there is index METADATA table with SDO_ROOT_MBR ( perhaps that is what Orest was saying ? ) but that is not correct MBR of geometries.
I understood that SelectExtents is supposed to :
works for SQL queries, works for subsets of data
It looks to me that Map is using SpatialExtents it to get not necessary exact extent of layer (class) not geometries.
So my question is, is SpatialExtents supposed to return MBR of geometries ?
I think for class extent we should have another command.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Fortin
Sent: Monday, November 17, 2008 11:24 PM
Subject: [fdo-internals] RE: FDO Function SpatialExtents
Map will use the SelectExtents function (if is exists) in order to compute the extent of the data set before it starts populating the cache.
The slower the SelectExtents  function is the slower Map rendering will be.  SDO_AGGR_MBR is probably not efficient enough for that purpose.
RF
Sent: Monday, November 17, 2008 5:36 PM
Subject: [fdo-internals] FDO Function SpatialExtents
I have implemented support for SelectAggregates in King.Oracle.
I am testing SpatialExtent function and I need help in understanding how clients, MAP 3D , is using it. I am not sure if I understand how is it supposed to be used.
I have implemented function using Oracle SDO_AGGR_MBR. That is rather slow process .
What I noticed is that MAP 3D 2009 is calling FDO command SelectAggregates with SpatialExtents function.
That makes rendering of layers very slow in MAP 3D.
I know I am asking about non-open source client like MAP 3D but from what I see makes me wonder if I understand SpatialExtents function correctly.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081118/8ec31acc/attachment-0001.html
More information about the fdo-internals mailing list
