[fdo-internals] RE: FDO Function SpatialExtents
Dan Stoica
dan.stoica at autodesk.com
Wed Nov 19 10:14:41 EST 2008
> I think Autodesk.Oracle provider is calculating from SDO_ROOT_MBR data only
No, for geodetic CS Autodesk.Oracle provider is doing a brute force calculation using a select at OCI level.
Dan.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Tuesday, November 18, 2008 5:03 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: FDO Function SpatialExtents
SDO_TUNE.EXTENT_OF has few limitations like schema access and only works for particullar number of dimensions
and still takes some time to calculate.
I think Autodesk.Oracle provider is calculating from SDO_ROOT_MBR data only (it is not exact extent in any case ).
I am hoping that formula will be shared here :)
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, November 18, 2008 10:28 PM
What does
SELECT SDO_TUNE.EXTENT_OF('TABLENAME','GEOMCOLUMN') FROM DUAL
Give you for a geodetic table?
This post makes it look like retrieving the MBR of geodetic CS from the index metadata table is non-trivial:
http://kr.forums.oracle.com/forums/thread.jspa?threadID=523315
Jason
Sent: Tuesday, November 18, 2008 13:20
SDO_ROOT_MBR is not even close to layer extent for geodetic CS.
Any clue how Autodesk.Oracle provider is calculating index extent from that SDO_ROOT_MBR for geodetic CS?
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
