[fdo-internals] FDO RFC 21 - New Linux Buildsystem Cmake Based
Jason Birch
Jason.Birch at nanaimo.ca
Fri Nov 28 10:29:57 EST 2008
Hi Greg,
I don't know about you, but my time for meetings right now is pretty limited.
Would you be happy going ahead with this in a sandbox, working out all of the issues (making sure that the tests are run, passed as part of the build) to your satisfaction, and then committing to trunk once it's working and we're all happy with it? Although the changes would be non-intrusive, this would Helio to make any required changes to the FDO code without having to go through patch approval for each one, and it would keep the trunk stable.
I know I'm reversing my thinking on this one, but it does make sense.
Jason
From: fdo-internals-bounces at lists.osgeo.org on behalf of Greg Boone
To: FDO Internals Mail List
Subject: RE: [fdo-internals] FDO RFC 21 - New Linux Buildsystem Cmake Based
Maybe we should have a PSC meeting to discuss this issue? I would like to put this issue to bed.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Wednesday, October 22, 2008 9:02 AM
Subject: Re: [fdo-internals] FDO RFC 21 - New Linux Buildsystem Cmake Based
On Terça 21 Outubro 2008 15:34:00 Jason Birch wrote:
> 3) To my knowledge this process has only been run and tested against
> Mandriva. I'll be happy to do the same against Ubuntu for sure, and may
> find time to set up VMs for Debian and a recent version of CentOS as
> well. Helio, do you know if there is any intention of adding MapGuide
> support to the other GeoLinux distributions? Are there any problems
> running the unit tests?
Well, GeoLinux itself is a project started in Ecos to create global packages.
At this moment, as exception for the Mapguide Live cd's, i didn't see any
distro or gis based distro taken on mapguide. Is usually mapserver and mostly
the Java stacks.
I didn't made unit tests run just because i tried use external cppunit, but i
will fall in use the ThirdParty one, as works only with that.
> 4) Helio has taken on responsibility for maintaining the CMake build
> process for GeoLinux (on Mandriva) and has done so for more than a year
> in a consistent manner. I am personally willing to commit to learning
> CMake and helping to maintain it for FDO as well. Are either of these
> commitments as reliable as a full time paid position? Absolutely not,
> but I don't believe it is realistic to expect that from the open source
> community.
Yes, i just still not hapy to not been able to get rid of dbxml23 + xerces 2.7
+ xqilla 1.0.1 + db 4.5 and can only work with that. Using db 4.6 cause
headaches every new try.
> BTW, I've been working with the CMake build process for MapGuide that
> Helio just posted to the MapGuide-internals list. It seems simple and
> intuitive so far, in a way that I've never felt about the auto* chain.
> If it is desired to have a mechanism to build using the included
> libraries, it seems quite feasible to create something like the
> build_linux.sh script that sets up the required command line options to
> CMake.
Is a text shell oriented script, even the tests are easy to do
KDE Project
Brasil and South America Primary Contact
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081128/761529fe/attachment.bin
More information about the fdo-internals
