[fdo-internals] RFC 26 - New Extended Select command and Scrollable
 Reader - for review
    Orest Halustchak
    orest.halustchak at autodesk.com
    Fri Oct 17 12:37:29 EDT 2008
I'd like to bring your attention to RFC 26 ( http://trac.osgeo.org/fdo/wiki/FDORfc26 ) which proposes to add a new Extended Select command with uses a Scrollable feature reader. Basically, this takes what currently are custom commands in the SDF, SHP, and recently SQLite providers and makes them generic FDO commands. This will remove special case handling for applications that currently use these and open the door for generic use by any application.
Please review and provide your feedback.
Thanks,
Orest.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081017/626ac532/attachment.html
More information about the fdo-internals
