[fdo-internals] RFC 26 - New Extended Select command
andScrollable Reader - for review
Jason Birch
Jason.Birch at nanaimo.ca
Mon Oct 20 15:03:13 EDT 2008
I don't have any direct experience with this because MapGuide doesn't
currently doesn't allow access to these commands. I certainly see value
in making these part of the common feature set though. Maybe I'll
eventually be able to do sorting on SDF results via MapGuide J
One thing that occurred to me when reading this RFC was that I'd like to
see a mechanism to "page" through results; similar to the LIMIT clause
in MySQL. When displaying result sets in a web environment, you often
want to give the user a small set of the data, and then page through the
results N records at a time. I can currently brute-force this, but it
would be more efficient to handle this on the FDO side, especially for
providers where the underlying storage format has optimized methods of
dealing with it. The current enhancements would make this more
efficient to brute-force, but I wonder if adding parameters to the
initial selection (start record, number of results) would make this even
more efficient.
Jason
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest
Halustchak
Sent: Monday, October 20, 2008 11:24
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RFC 26 - New Extended Select command
I wonder if anyone has any comments on this. If nobody has any
objections to it, I'd like to bring it to a vote soon.
Thanks,
Orest.
Halustchak
Sent: Friday, October 17, 2008 12:37 PM
Subject: [fdo-internals] RFC 26 - New Extended Select command and
I'd like to bring your attention to RFC 26 (
http://trac.osgeo.org/fdo/wiki/FDORfc26 ) which proposes to add a new
Extended Select command with uses a Scrollable feature reader.
Basically, this takes what currently are custom commands in the SDF,
SHP, and recently SQLite providers and makes them generic FDO commands.
This will remove special case handling for applications that currently
use these and open the door for generic use by any application.
Please review and provide your feedback.
Thanks,
Orest.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20081020/e7e3c61d/attachment.html
More information about the fdo-internals
