[fdo-internals] methods missing in IConnectionPropertyDictionary
Greg Boone greg.boone at autodesk.com
Wed Sep 10 11:18:12 EDT 2008
Why don't you make the required changes and submit a patch?
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Wednesday, September 10, 2008 5:06 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] methods missing in IConnectionPropertyDictionary
It looks like those two methods are not exposed in the managed API. Otherwise
they would be in here:
http://trac.osgeo.org/fdo/browser/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp
Best to file a ticket.
- Jackie
geostarter wrote:
> Hallo
> I'm writing some code accessing FDO with the managed FDO API. I want to
> find out if a connection property is a filename or filepath, before
> establishing a connection, but in the IConnectionPropertyDictionary
> interface the methods isFilename and isFilepath are missing. In the
> unmanaged API I can find this methods in the
> FdoIConnectionPropertyDictonary class (I'm confused :confused: ).
> In the managed API i have find these methods in
> IDataStorePropertyDictonary interface, but this i get only executing a
> Create or Destroydatastore Command, what i don't want, because i want to
> read files via FDO.
> What can i do to get the "isFilename" and "isFilePath" information before
> establishing a connection? Hope someone can help me! Thanks!!!
> greets
> geostarter
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/methods-missing-in-IConnectionPropertyDictionary-tp19407768p19409465.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
