[fdo-internals] methods missing in IConnectionPropertyDictionary
Greg Boone greg.boone at autodesk.com
Thu Sep 11 12:25:56 EDT 2008
Can you send me the .patch file directly? I can't download if from the wiki.
You should also fill out and submit a contributor agreement.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Wednesday, September 10, 2008 10:57 PM
To: fdo-internals at lists.osgeo.org
Subject: RE: [fdo-internals] methods missing in IConnectionPropertyDictionary
Done.
http://trac.osgeo.org/fdo/ticket/388
- Jackie
gregboone wrote:
> Why don't you make the required changes and submit a patch?
> Sent: Wednesday, September 10, 2008 5:06 AM
> Subject: Re: [fdo-internals] methods missing in
> It looks like those two methods are not exposed in the managed API.
> Otherwise
> they would be in here:
> http://trac.osgeo.org/fdo/browser/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp
> Best to file a ticket.
> - Jackie
> geostarter wrote:
>> Hallo
>> I'm writing some code accessing FDO with the managed FDO API. I want to
>> find out if a connection property is a filename or filepath, before
>> establishing a connection, but in the IConnectionPropertyDictionary
>> interface the methods isFilename and isFilepath are missing. In the
>> unmanaged API I can find this methods in the
>> FdoIConnectionPropertyDictonary class (I'm confused :confused: ).
>> In the managed API i have find these methods in
>> IDataStorePropertyDictonary interface, but this i get only executing a
>> Create or Destroydatastore Command, what i don't want, because i want to
>> read files via FDO.
>> What can i do to get the "isFilename" and "isFilePath" information before
>> establishing a connection? Hope someone can help me! Thanks!!!
>> greets
>> geostarter
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/methods-missing-in-IConnectionPropertyDictionary-tp19407768p19409465.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://www.nabble.com/methods-missing-in-IConnectionPropertyDictionary-tp19407768p19426989.html
More information about the fdo-internals mailing list
