[fdo-internals] Naming Conventions for debug build???
UV
uvwild at gmail.com
Wed Apr 8 10:50:55 EDT 2009
Ah, you mean kind of hot swapping... Interesting idea.
Fair enough. It just gets a little bit confusing when you are actually
have the debug and release versions of each....
I did the hot swapping by moving Bin directories around.... and i got
really confused which FDO I was ending up with....
I like unix for the lib version numbers in the filenames... thats so
much cleaner....
Thanks for the clarification.
Traian Stanev wrote:
> This way you can use a debug build of MapGuide against an installed or otherwise available release build of the FDO SDK. If the debug MapGuide linked to Fdod.dll instead of Fdo.dll, you would be forced to compile your own debug FDO in order to compile a debug MapGuide.
> Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of UV
> Sent: Tuesday, April 07, 2009 9:37 PM
> To: fdo-internals at lists.osgeo.org
> Subject: [fdo-internals] Naming Conventions for debug build???
> Hi,
> in the mapguide project and elsewhere the debug versions of the
> libraries have a d suffix in their names.
> In the FDO build this is not the case.
> Basically having different library versions with the same name on the
> system seems not like a good way to go.
> I noticed this as a factor in introducing additional configuration
> problems into my developing system.
> Is there a good reason to do it like this or is this just an unfinished
> piece of configuration management and things have not been aligned
> properly as yet ???
> Any thoughts?
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
