[fdo-internals] Problem compiling provider for Autodesk Map 2010
Bruno Scott
bscott at geomapgis.com
Fri Apr 17 10:21:37 EDT 2009
I have added "C:\Program Files\AutoCAD Map 3D 2010\FDO\bin" to the path
and i still have the same problem.
Map says
Unable to create connection to provider 'OSGeo.PostGIS.3.4'
Unable to load the FDO Provider: The specified procedure could not be found
View this message in context: http://n2.nabble.com/Problem-compiling-provider-for-Autodesk-Map-2010-tp2650844p2650999.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
