[fdo-internals] FDO documentation questions
Jackie Ng jumpinjackie at gmail.com
Tue Jan 13 08:41:11 EST 2009
Sorry to necro this thread, but has this been confirmed that support for
parameters implies support for batch insertion?
There is currently no actual capability API to test for batch insert
support, and all known batch insert code samples (including my
implementation in FDO Toolbox) assumes parameters are supported to do the
batch insert.
Is this the case?
- Jackie
Donald Cameron wrote:
> Hi,
> I am working on the FDO documentation: The Essential FDO, The FDO
> Developers Guide, and the FDO API Reference.
> I was going to write some sample code that does batch inserts using the
> OSGeo.FDO.Commands.BatchParameterValueCollection property of the
> OSGeo.FDO.Commands.Feature.IInsert command but I was told that no
> providers support batch insertion.
> I currently believe that the SupportsParameters() method of
> OSGeo.FDO.Connections.Capabilities.ICommandCapabilities says whether a
> provider supports batch inserts.
> According to a program I wrote, three providers support parameters:
> ArcSDE, KingOracle, and PostGIS.
> So my question is this: Do they actually support batch insertion?
> If so, I would be very grateful for some sample code showing how to use
> BatchParameterValueCollection to do batch insertion.
> Regards,
> Don
> Don Cameron
> Autodesk Inc.
> Developer Publications Specialist
> Ottawa, Ontario, Canada
> 613.233.3758
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://n2.nabble.com/FDO-documentation-questions-tp2051215p2151173.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
