[fdo-internals] RE: [fdo-users] AutoCAD Map3D and Oracle FDO
Issues
Mike Toews
mwtoews at sfu.ca
Fri Jun 12 17:15:39 EDT 2009
Hi Orest,
Orest Halustchak wrote:
> Hi Mike,
> I'd like to clarify what issues are happening here.
> 1. Both Oracle and PostGIS are mentioned. Is the problem the same with both of these or are we talking about different problems?
I've only been dealing with PostGIS for the past year. My experience
with Oracle was too brief, and was before any attempts to integrate with
FDO.
Here is an example PostGIS schema, explanation of behaviour, and workaround:
CREATE TABLE myfeaturetable
gid serial NOT NULL,
geometry geometry, -- select
addgeometrycolumn('','myfeaturetable','geometry',26910,'MULTIPOLYGON',2)
CONSTRAINT myfeaturetable_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_geometry CHECK (ndims(geometry) = 2),
CONSTRAINT enforce_geotype_geometry CHECK (geometrytype(geometry) =
'MULTIPOLYGON'::text OR geometry IS NULL),
CONSTRAINT enforce_srid_geometry CHECK (srid(geometry) = 26910)
WITH (OIDS=FALSE);
INSERT INTO geometry_columns(f_table_catalog, f_table_schema,
f_table_name, f_geometry_column, coord_dimension, srid, "type")
VALUES ('', 'public', 'myfeaturetable', 'geometry', 2, 26910,
'MULTIPOLYGON');
Connecting this geometry feature to Map3D 2008/2010, and inserting a
simple 1-piece closed polyline triggered the enforce_geotype_geometry
check error, and it wasn't inserted. Here are the error messages from
AutoCAD Map3D 2010 using the second method described below in question #4:
<Error code="200" type="5" dispensation="1" sId="2"
occurrence="1">Feature was not saved in the target feature source.
<Parameters>
<Parameter classId="0" position="0">
<Message>2=The execution of SQL statement failed with PostgreSQL error
code: PGRES_FATAL_ERROR, ERROR: new row for relation "myfeaturetable"
violates check constraint "enforce_geotype_geometry" .</Message>
<SQL />
</Parameter>
<Message>1=Failed to execute Fdo command.</Message>
<SQL />
</Parameter>
<Message>Failed to insert feature.</Message>
<SQL />
</Parameter>
<Message>FdoPostGIS:myfeaturetable (), Rev# <0></Message>
<SQL />
</Parameter>
</Parameters>
<Entry code="1" type="15" sId="3" occurrence="1">Failed to save some
features.</Entry>
<Entry code="1" type="15" sId="4" occurrence="1">Failed to save edit
set.</Entry>
I quickly discovered that Map3D was sending a geometry with type
'POLYGON'. I've seen the same behaviour in Map3D 2008 and 2010 with
MULTIPOLYGON and MULTILINE geometry types (I'll also assume MULTIPOINT
features, but I don't use these).
So my workaround solution in detail is a trigger function. This is used
on several tables with MULTI-geometries as a BEFORE UPDATE OR INSERT
trigger.
CREATE OR REPLACE FUNCTION make_multifeature_fn()
RETURNS trigger AS
$BODY$BEGIN
IF ST_GeometryType(NEW.geometry) IN('POLYGON','LINESTRING','POINT') THEN
NEW.geometry := ST_Multi(NEW.geometry);
END IF;
RETURN NEW;
END;$BODY$ LANGUAGE 'plpgsql' IMMUTABLE COST 100;
CREATE TRIGGER myfeaturetable_multipolygon_tg
BEFORE INSERT OR UPDATE
ON myfeaturetable
FOR EACH ROW
EXECUTE PROCEDURE make_multifeature_fn();
Things have been smooth sailing since, and is seamless from the AutoCAD
side.
> 2. So, you have a geometry that is defined as just Multi-Polygon. If Oracle, how did you define it as just multi-polygon? What does your schema look like.
I don't have access to Oracle at the moment, so I can't comment.
> 3. In PostGIS, you used MULTIGEOMETRY when you added the geometry column?
Yes, using the built-in 'SELECT AddGeometryColumn()' function, which
adds the data constraints and the metadata to geometry_columns.
> 4. In Map3D's display manager, when you ask to create a new feature, which geometry type options does it show?
After connecting and right-clicking the data manager, here is the menu
and submenu:
Create:
- Create new Polygon myfeaturetable
- Create new MultiPolygon myfeaturetable
The other method to insert is described to me by a CAD technician across
the desk from me:
1. Draw a Polyline, and ensure that it is closed
2. Right-click the layer and choose 'Create new feature from geometry'
3. Click the closed polyline(s) then enter
4. After this, a table is displayed where any other metadata can be
filled out for the features
5. Check-in features
With this method, it is ambiguous if the closed polyline is singlepart
or multipart.
> 5. You mentioned arcs. Is this a separate issue that you are having? As Dan mentioned, Oracle doesn't support arcs in geometry that is lat/long.
I'm only dealing with simple straight-line features. Some are stored in
EPSG:4326 (lat/long), and other are stored as projected UTM coordinates.
Let me know if any more details are needed. Thanks for looking into this.
-Mike
> Thanks,
> Orest.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mike Toews
> Sent: Friday, June 12, 2009 2:21 PM
> To: FDO Users Mail List; FDO Internals Mail List
> Subject: Re: [fdo-users] AutoCAD Map3D and Oracle FDO Issues
> This issue requires a database-end workaround, which varies depending on
> DB software.
> That said, who is at fault? Is it an issue with AutoCAD Map3D or FDO? If
> it is an AutoCAD issue, should FDO be responsible for inserting/updating
> the same geometry type as the feature source? Is AutoCAD intentionally
> mixing single and mixed geometries, and is this allowed among some or
> all providers? I never bothered submitting at ticket on this issue since
> I wasn't sure what exactly the issue was and who to blame.
> -Mike
> Martin Morrison wrote:
>> It's not an AutoCAD/FDO function, it's an Oracle database function. Read up on the triggers in the Oracle docs.
>> Martin
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Tony
>> Sent: Friday, June 12, 2009 1:59 AM
>> To: fdo-users at lists.osgeo.org
>> Mike
>> thanks in millions for answer. could you tell me how to implement the
>> trigger from autocad insert.
>> i am new to autocad .
>> thanks
>> tony
>> Mike Toews wrote:
>>> Tony,
>>> I think I had a similar problem, although I'm using Map3D 2008/2010 with
>>> a PostgreSQL/PostGIS database. The issue was Map3D was creating and
>>> sending a [single] POLYGON object to a MULTIPOLYGON column, which it
>>> shouldn't, since the column has check constraints to ensure they are all
>>> MULTIPOLYGON geometries. I fixed it by writing a simple BEFORE INSERT OR
>>> UPDATE trigger to check and correct if the polygon is a multi object.
>>> I'm no pro with Oracle spatial, but the guts of my PL/pgSQL (with
>>> PostGIS) trigger function look somthing like this:
>>> IF ST_GeometryType(NEW.geometry) IN('POLYGON','LINESTRING') THEN
>>> END IF;
>>> I think most of this is portable to your situation, except that
>>> ST_GeometryType() returns different values. I'm not sure if there is a
>>> generic ST_Multi() function, but there are similar casts that you can use.
>>> Hope this helps,
>>> -Mike
>>> Tony wrote:
>>>> i am using fdo (autodesk) as well as used king fdo for getting the CAD
>>>> data
>>>> write to oracle.
>>>> here is the whole story : i have a polygon shape file i have used FDO2FDO
>>>> to
>>>> create oracle table , I want to edit some of geometries in AutoCADmap 3D
>>>> as
>>>> well as i want to add new polygons there.
>>>> the issue: i have createa a closed polygon in autocadmap that have Arc
>>>> and
>>>> line and i was trying to write this to the above created table. i am
>>>> getting error saying that geometry type does not match,
>>>> after reading the logs i found out that though my Oracle table has
>>>> mpolygon
>>>> geometry type i can not write and polygon with Arc(true arc) in it.
>>>> any idea how to solve this issue. i have wote to autodesk and still
>>>> wating
>>>> to get the answer. i wrote to king fdo no reply yet ...
>>>> please let me know how to solve this
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
