[fdo-internals] King Oracle Issue
Haris Kurtagic
haris at sl-king.com
Tue Jun 16 06:53:11 EDT 2009
Hi Tomas,
Regarding names of FDO classes and their representation in underlying data store is something which could be pain but I don't see right solution (other then use of additional metadata to describe generated name for FDO class). It is not only problem of King.Oracle or rdbms providers but also files. There are some steps in King.Oracle that could create names of FDO classes which would more look like original, but no 100% solution.
KingFdoClass is metadata table which works and we use it a lot. You need to add row to it after creating table in Oracle. Row in KingFdoClass metadata table will not be auto added with apply schema command.
- Schema is cached because of performance reasons. Right now it is necessary because of extensive use of DescribeSchema command by current FDO clients. I would much more prefer that schema would not be cached but right now it would not be practical.
- Perhaps we changed something. As far as I remember it was different schema.
- I was thinking about auto-updating metadata table with apply schema. But there are few scenarios in which it would not be possible. Also trough our experience of use of provider in our projects we realized we don't need it.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Thomas Knoell
Sent: Monday, June 15, 2009 9:43 PM
To: 'FDO Internals Mail List'
Subject: RE: [fdo-internals] King Oracle Issue
Hi Haris,
I got by the describe schema issue I had with the King Oracle provider. Executing the describe schema command after applying the schema now works fine.
One thing that is unpleasant is the fact that the describe-schema implementation in the provider returns class names for feature classes that do not match the original class name: the new name is a combination of data store, class and geometry property name, all concatenated by a hyphen (for example DB1~MYCLASS~GEOM). That means that the application needs a provider specific implementation where the original class name can be mapped to the one the King Oracle provider uses.
The link you provided in a previous mail describes a possibility to define a new class name of an existing geometry table using a King Oracle meta data table and hence providing a workaround to the fact that feature class names are altered. I applied this to the feature classes I created with the apply-schema command but it did not work: rather than replacing the name (for example) DB1~MYCLASS~GEOM with NewClass, it actually returns two classes now: DB1~MYCLASS~GEOM and NewClass (for which no table actually exists). Since the site you point to mentions that this option is in a BETA release status, I assume that either this may not be supported yet or I had an incorrect expectation. Could you please comment on this.
There are a couple of other issues with this meta data table:
Ø I updated the meta data table from the application after successfully applying the schema. Unfortunately, to have those changes take effect, I have to close and re-open the connection. before executing the describe schema command. I believe this should not be necessary.
Ø Your site states that non feature classes identified via the meta data table belong to a schema named KingFdoClass. This is currently not the case as those classes are listed as members of the schema KingOra. Will this change for the final release?
In my last mail I asked whether or not you plan to automatically maintain the meta data table if a schema is applied. Can you please comment on this as well?
Thanks
Thomas
Sent: June-10-09 5:21 PM
Hi Haris,
Thanks for the provided link, that is helpful.
I created the table, added the information to the connection string and executed the test. I noted that the ApplySchema command is not adding any specified non feature classes to that table. Since the link you provided indicates that this is in Beta release at this point, is your final version enhancing your ApplySchema command implementation to automatically update this table for non feature classes?
Thanks
Thomas
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: June-10-09 5:01 PM
To: FDO Internals Mail List
For tables which are not in sdo_geom_metadata you need to add them using "KingFdoClass" table (http://www.sl-king.com/fdooracle/KingFdoClass.htm).
One reason I can remember right now for not working, would be because FDO schema is cached. You would need to restart provider ( there is also non-standard FDO function in King.Oracle connection).
Haris
Sent: Wednesday, June 10, 2009 10:13 PM
Hi Haris,
Here are the answers to your questions:
>> How did you applied schema ? You mention feature and non-feature class ?
I executed the apply schema command (see below) from the FDO application. The schema that is defined and then applied contains a FdoFeatureClass and FdoClass. The application has to work with data stores that contain tables with and without spatial information and must be able to maintain them. That is why the test schema contains both classes.
>> You applied Autodesk schema , metadata tables?
The original data store did not contain any tables. However, since you mentioned it here, I added the f_* tables and tried it again - same result.
>> In King.Oracle for Oracle Table to become available as FDO class the table has to be in sdo_geom_metadata . You did that ?
>> Of 'course Oracle user you are using to connect has to see those tables etc...
Since the schema was applied with the FdoIApplySchema interface, this should have been taken care of automatically. I checked and the feature class table does show up in sdo_geom_metadata. Obviously, the non feature class does not. And the Oracle user the application is connecting to can see those tables. So, are you saying that if I connect to an Oracle data store that does have tables without spatial information, I would not be able to use the insert/delete/update commands to maintain them when working with the King Oracle provider?
Thanks
Thomas
FdoPtr<FdoIApplySchema> apply_schema_cmd =
(FdoIApplySchema*) fdo_connection->CreateCommand(
FdoCommandType_ApplySchema);
FdoPtr<FdoFeatureSchemaCollection> schemas =
FdoFeatureSchemaCollection::Create(NULL);
FdoPtr<FdoFeatureSchema> schema =
FdoFeatureSchema::Create(L"TestSchema", L"Test Schema");
FdoPtr<FdoClassCollection> classes = schema->GetClasses();
printf(" -> Defining feature class fc \n");
FdoPtr<FdoFeatureClass> fc_class = FdoFeatureClass::Create(L"fc", L"fc");
fc_class->SetIsAbstract(false);
FdoPropertyDefinitionCollection *data_property_definitions =
fc_class->GetProperties();
FdoDataPropertyDefinitionCollection *id_property_definitions =
fc_class->GetIdentityProperties();
FdoDataPropertyDefinition *data_property_definition =
FdoDataPropertyDefinition::Create(L"IdProp", L"IdProp");
data_property_definition->SetDataType(FdoDataType_Int64);
data_property_definition->SetNullable(false);
data_property_definition->SetIsAutoGenerated(true);
data_property_definitions->Add(data_property_definition);
id_property_definitions->Add(data_property_definition);
FDO_SAFE_RELEASE(data_property_definition);
FdoDataPropertyDefinition::Create(L"Prop1", L"Prop1");
data_property_definition->SetDataType(FdoDataType_Int32);
data_property_definition->SetNullable(true);
data_property_definition->SetIsAutoGenerated(false);
FdoGeometricPropertyDefinition *geometric_property_definition =
FdoGeometricPropertyDefinition::Create(L"GProp",L"GProp");
geometric_property_definition->SetGeometryTypes(
FdoGeometricType_Point |
FdoGeometricType_Curve |
FdoGeometricType_Surface |
FdoGeometricType_Solid );
geometric_property_definition->SetHasElevation(true);
data_property_definitions->Add(geometric_property_definition);
fc_class->SetGeometryProperty(geometric_property_definition);
FDO_SAFE_RELEASE(geometric_property_definition);
FDO_SAFE_RELEASE(id_property_definitions);
FDO_SAFE_RELEASE(data_property_definitions);
fc_class->SetBaseClass(NULL);
classes->Add(fc_class);
printf(" -> Defining non feature class nfc \n");
FdoPtr<FdoClass> nfc_class = FdoClass::Create(L"nfc", L"nfc");
nfc_class->SetIsAbstract(false);
data_property_definitions = nfc_class->GetProperties();
id_property_definitions = nfc_class->GetIdentityProperties();
nfc_class->SetBaseClass(NULL);
classes->Add(nfc_class);
schemas->Add(schema);
printf(" -> Applying the schema \n");
apply_schema_cmd->SetFeatureSchema(schema);
apply_schema_cmd->Execute();
Sent: June-10-09 3:28 PM
How did you applied schema ? You mention feature and non-feature class ? You applied Autodesk schema , metadata tables?
Haris
Sent: Wednesday, June 10, 2009 8:42 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] King Oracle Issue
I am working on a FDO based application that should use the King Oracle Provider to connect to a data source on an Oracle 11g instance. The application currently connects fine to an empty data store (the data store does not contain any tables) and successfully applies a test schema that consists of a feature and a non feature class. The problem arises in the following step where a describe schema request is executed. In this case, the result is one schema named KingOra and no classes. I expected the test schema and its corresponding classes being reported.
The application has access to all the DLLs that come with FDO. The DLLs were created by compiling the projects from the trunk in release mode. Due to the fact that I use MS Visual Studio C++ 2008 Express Edition, I had to open each solution and compile it separately as some of the projects referenced MFC files that are not available with the Express Edition. Those issues were corrected in the shadow and all builds succeeded.
Besides the changes to eliminate MFC references, one additional change was required in the King Oracle provider project in that the references to Oracle 10 libs were replaced by the corresponding Oracle 11 ones.
Using the command built.bat -c=release -a=install -o=c:\FdoHome on the FDO and ThirdParty directory, all DLLs were copied into the specified folder and hence made accessible to the FDO application.
The providers.xml file was modified to include the following statement for the King Oracle Provider:
<FeatureProvider>
<Name>King.Oracle.3.5</Name>
<DisplayName>King Provider for Oracle</DisplayName>
<Description>Read/write access to spatial and attribute data in an Oracle Spatial.</Description>
<IsManaged>False</IsManaged>
<Version>3.5.0.0</Version>
<FeatureDataObjectsVersion>3.5.0.0</FeatureDataObjectsVersion>
<LibraryPath>.\KingOracleProvider.dll</LibraryPath>
</FeatureProvider>
I did perform some debugging on the code. When following the statement that retrieves the schema name (see code below), I noted that it does not hit the function that implements the retrieval of the schema name but ends up in the function FdoCollection::GetCount() (file FDO\Unmanaged\Inc\Common\Collection.h). However, following other requests like the apply schema execute or the describe schema execute call, the correct functions are hit and executed. I also did some dependency checks on some DLLs and executables and nothing missing was reported.
I assume that this may be just a simple setup issue but after trying multiple things now, I reached a point where I am not sure what to try next. If someone has any suggestions I would appreciate the feedback. Also, if there are additional questions, please let me know.
Thanks
Thomas
FdoPtr<FdoIDescribeSchema> describe_schema_cmd =
(FdoIDescribeSchema*) fdo_connection->CreateCommand(
FdoCommandType_DescribeSchema);
FdoFeatureSchemasP schema_collection = describe_schema_cmd->Execute();
FdoInt32 schema_count = schema_collection->GetCount();
if (schema_count == 0)
printf(" -> No schemas found \n");
else
for (int s = 0; s < schema_count; s++) {
FdoFeatureSchemaP curr_schema = schema_collection->GetItem(s);
FdoStringP curr_schema_name = curr_schema->GetName();
printf(" -> Schema[%d]: %ls \n", s, (FdoString *)curr_schema_name);
FdoPtr<FdoClassCollection> curr_schema_classes =
curr_schema->GetClasses();
FdoInt32 curr_schema_class_count = curr_schema_classes->GetCount();
if (curr_schema_class_count == 0)
printf(" -> No classes found for current schema \n");
else
for (int sc = 0; sc < curr_schema_class_count; sc++) {
FdoPtr<FdoClassDefinition> curr_schema_class =
curr_schema_classes->GetItem(sc);
FdoStringP curr_schema_class_name = curr_schema_class->GetName();
printf(" -> Class[%d]: %ls \n",
sc,
(FdoString *)curr_schema_class_name);
} // for (int sc = 0; ...
} // for (int s = 0; ...
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090616/ea5c2c06/attachment-0001.html
More information about the fdo-internals
