[fdo-internals] King.Oracle & PostGIS provider failed with Empty tables
Traian Stanev traian.stanev at autodesk.com
Tue May 26 19:43:19 EDT 2009
Hi Bruno,
Does the PostGIS provider implement the SpatialExtents aggregate function? I seem to remember getting the same message with the OGR provider, and I think it was related to the lack of SpatialExtents capability.
Traian
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Tuesday, May 26, 2009 4:40 AM
> To: fdo-internals at lists.osgeo.org
> Subject: [fdo-internals] King.Oracle & PostGIS provider failed with
> Empty tables
> When adding an empty table using King.Oracle or PostGIS provider on
> AutoCAD
> Map 2010
> It throws this exception
> 'FdoPtr::operator->': Cannot execute function due to invalid value for
> the
> input parameter(s) 'p'.
> The exception comes from gwsfdo.dll and it is pretty hard to find the
> cause.
> After that it is not possible to use the "Create" function to add any
> records on the table.
> I'm trying to fix this issue on the PostGIS provider
> Does someone have any clue?
> Bruno
> View this message in context: http://n2.nabble.com/King.Oracle---
> PostGIS-provider-failed-with-Empty-tables-tp2973492p2973492.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
