[fdo-internals] RFC42 - Direct ArcSDE Provider :: Ready for Review
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Thu Nov 5 04:19:09 EST 2009
Jackie,
This query is good to help to explain two real-world issues here:
 1) The current implementation is for Oracle only and the SGID DB referenced
in the article is SQL Server - so that's a quick "no"!
Haris and I discussed the various options of providing a generic provider at
length and with the performance required, KingOracle platform in existence,
test data/systems available and the requirements for funding this the
project became an extension to KingOra.  The decoding of the metadata and
the SDE binary geometry *should* be available in the OpenSource submission
to be utilised in other direct providers such as the OSGeo SQLServer
provider.
 2) To enable direct access, the actual underlying host RDBMS credentials
(not ArcSDE server) will be required for an ArcSDE connection.  This
database may sit at a different security level to public services or may be
exposed with different port/username/password.  The SGID DB service exposed
in your sample is only the ArcGIS server details not the database
connection.
Hope this helps - I'll add some more detail to the RFC as this thread
develops.
 Crispin
Jackie Ng wrote:
> Would this direct ArcSDE provider support connecting to remote instances
> like this example here?
> http://gis.utah.gov/sgid_connect
> - Jackie
> Crispin_at_1Spatial wrote:
>> All,
>> I found the previous version of this message was still pending so am
>> resending.
>> I got confused between nabble and OSGeo subscriptions!
>> Please see the draft RFC available at:
>> http://trac.osgeo.org/fdo/wiki/FDORfc42
>> I hope it will be of interest - especially as a platform for involvement
>> and as a potential vehicle to support ArcSDE in 64-bit.
>> The instructions for http://trac.osgeo.org/fdo/wiki/FDORfcs do not
>> indicate how to get a PSC guide assigned (required I presume) ... how
>> does this element work?
>>  Regards,
>>   Crispin
>> 1Spatial.com
View this message in context: http://n2.nabble.com/RFC42-Direct-ArcSDE-Provider-Ready-for-Review-tp3950148p3951080.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
