[fdo-internals] FDO PostGIS provider developments
Haris Kurtagic haris at sl-king.com
Mon Nov 30 10:25:54 EST 2009
I wouldn't like to go to much into discussion about generic rdbms stuff. I
think that priority should be having good PostGIS provider which we can get
with current resources.
Just in short, when I started looking how to make provider for Oracle,
Generic RDBMS was first place to start looking. For me Generic RDBMS was to
complex , hard to work with and extend . Performance was also bad.
That was few years ago, I would assume that it has improved since but still
I am afraid that Autodesk would be only maintaner of that code. That would
be main reason why I would like to have current PostGIS available, which has
not only Autodesk developers which could work on it.
Haris
On Mon, Nov 30, 2009 at 2:36 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> 2009/12/1 Haris Kurtagic <haris at sl-king.com>:
> > Is it necessary to replace current version, can't that be another version
> of
> > provider ?
> > I was never able to get comfortable with generic rdbms stuff. In my
> opinion
> > there are minuses too.
> like?
> > I would like to have option of current code base to be continued if there
> > would be option at least for some time.
> > Haris
> > On Mon, Nov 30, 2009 at 2:14 AM, Orest Halustchak
> > <orest.halustchak at autodesk.com> wrote:
> >> Hi,
> >> Autodesk has had interest from Map3D customers who want to use the FDO
> >> PostGIS provider to access and edit data using Map3D and other products.
> >> These customers have not been able to use this provider reliably with
> >> Map3D. We had a close look at the provider code to determine what work
> would
> >> be needed to complete the implementation of schema and edit support and
> fix
> >> other issues. Unfortunately, we found that the provider as it stands
> today
> >> requires a lot of work to complete the implementation of required FDO
> >> interfaces and to add good unit test coverage. Things that still need a
> fair
> >> bit of work include:
> >> ·         Creating new schema and new datastore
> >> ·         Spatial filter handling
> >> ·         Huge memory leaks on insert.
> >> ·         Not all schema commands are implemented.
> >> ·         Enable and fix transaction support.
> >> ·         Constraint and default values support.
> >> ·         Lots of TODOs spread all over the code
> >> ·         Virtually no unit tests exist.
> >> We looked at the level of effort needed to complete that work. It was
> >> quite high. So, we looked at an alternative. There exists an earlier
> open
> >> source community code base for a PostGIS provider that was started a
> couple
> >> of years ago but not finished. That code base used the generic rdbms
> >> framework that is shared with the SQL Server Spatial, MySQL, and ODBC
> >> providers. Most of the schema processing is handled with that shared
> code.
> >> We spent some time working with the current provider and the other code
> base
> >> to determine the most efficient way to get to a completed provider that
> >> would be robust, perform well, and be maintainable.
> >> In the end, we determined that taking the earlier code base, adding
> >> support for the recent fdo interface changes, and completing other parts
> >> that weren’t finished would take much less time. Also, based on
> performance
> >> comparisons, we would get something that was much faster on inserts and
> >> selects, e.g. the select performance is about six times faster and
> schema
> >> describe is about three times faster. We couldn’t compare insert times
> very
> >> well because the current provider kept crashing after a certain point
> and we
> >> couldn’t insert a large number of features.
> >> So, what we would like to do is complete our work to get a working
> PostGIS
> >> provider and then replace the current open source code with our new
> copy.
> >> Note that we plan to use native PostGIS schema without adding additional
> >> metadata tables just as the current provider does. It will be able to
> read
> >> any schemas created by the current version of the provider and itself
> will
> >> generate generic PostGIS schemas.
> >> We’ll need to submit an RFC for this, but we wanted to get this
> >> information out to you ahead of time.
> >> At the same time, we are planning to change the connection parameters to
> >> separate out the database name from the service name. This will make it
> >> easier for users. They can identify the service (e.g. localhost:5432),
> and
> >> then see the available datastores from which they can choose in a UI.
> Then,
> >> PostGIS schema simply will map to FDO schema. The main drawback to this
> is
> >> that any users with existing MapGuide feature sources and layer
> definitions
> >> will have to update them.
> >> In the end, we will end up with a good functioning provider that
> performs
> >> well.
> >> Regards,
> >> Orest.
> >> _______________________________________________
> >> fdo-internals mailing list
> >> fdo-internals at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/fdo-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20091130/5dc987a8/attachment.html
More information about the fdo-internals mailing list
