[fdo-internals] RE: [mapguide-internals] FDO RFC 43 - Standard FDO Class Naming Conventions
Orest Halustchak orest.halustchak at autodesk.com
Thu Oct 29 09:20:49 EDT 2009
Hi Haris,
Yes, datastore is identified at the connection. So, I probably shouldn't have used the term "qualifier" for datastore, but maybe grouping mechanism. Datastore contains schemas, which contain classes. You connect to the datastore and then have access to the schemas and classes within that datastore.
>From the FDO developers guide, datastore is defined this way: "A data store is a repository of an integrated set of objects. The objects in a data store are modeled either by classes or feature classes defined within one or more schemas."
For the SQL Server case, a SQL Server database matches well with FDO datastore. Tables within an SQL Server database are qualified by a schema name. The default is "dbo", but you can define your own. Thus, we can match SQL Server schema with FDO schema and SQL Server table with FDO class. So, in my example, CityOfNewYork and CityOfAlbany can be captured as SQL Server databases and that's how the SQL Server Spatial provider handles this. PostGIS also has a similar physical structure, although the FDO PostGIS provider currently does not take advantage of it and I think that's a bug.
For the Oracle case, how do you capture separate FDO datastores within an Oracle instance? The main grouping mechanism within an Oracle instance is an Oracle owner (Oracle confuses things by using terms 'owner', 'user', and 'schema' for almost the same thing). So, if we use that grouping mechanism for FDO datastore (else how do we handle multiple datastores within an Oracle instance) and we map FDO classes to Oracle tables at the bottom end, then we are missing a way to represent FDO schemas unless we add some additional metadata to track that mapping. Without that mapping present, then we can default to only a single FDO schema per datastore. An issue with using Oracle schema for FDO schema is how would you distinguish between CityOfNewYork.LandBase from CityOfAlbany.LandBase?
Thanks,
Orest.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Wednesday, October 28, 2009 4:20 PM
To: 'FDO Internals Mail List'
Subject: RE: [fdo-internals] RE: [mapguide-internals] FDO RFC 43 - Standard FDO Class Naming Conventions
Hi Orest,
I maybe wrong, but would like to clarify it with you. Datastores are
introduced basically with metadata tables describing fdo classes. So in that
sense I understand that in one database we could have multiple datastores
but trough metadata tables. With concept of what later called "native"
database classes there are no datastores ? That is my observation and same
time question to you.
Similar, regarding SQL server eventually we don't have database as level,
because database is defined in connection string, right ?
I agree about separate fdo classes for tables with multiple geometries, it
would be nicer to have one class with multiple geometries.
But, I think some APIs and even FDO based applications are making assumption
about that one geometry is "main geometry".
There is no way that provider could construct FDO class from such table, to
know what is main geometry (without metadata).
Haris
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: Wednesday, October 28, 2009 1:57 PM
To: FDO Internals Mail List
Note that there is another qualifier that should be taken into account in
these discussions and that is the datastore name. There are really three
levels of qualification: datastore name, schema name, class name. So, cases
where it is suggested to use the file name as the schema name, if the file
name is already used for the datastore name, it doesn't have to be used
again for the schema name.
An issue with rdbms is that some such as SQL Server include the three levels
of database, schema, and table. Others such as Oracle do not. So in the
Oracle case if we map the datastore name to the Oracle user/schema, then we
should not also use Oracle user/schema for FDO schema.
Consider this example.
	FDO Datastore = CityOfNewYork
		FDO Schema = LandBase
			Class = Parcel
			Class = Road
		FDO Schema = Water
			Class = Pipe
			Class = Valve
		FDO Schema = Gas
			Class = Pipe
	FDO Datastore = CityOfAlbany
		Same schemas and classes
We don't want to mix up the parcels from CityOfNewYork with the parcles from
CityOfAlbany, those should be in separate tables. Having the Oracle schema
name as LandBase, Water, and Gas doesn't handle this.
Also, about the ~ColumnName convention being used for geometry columns, note
that FDO does allow more than one geometry column per class with one flagged
as the main geometry. I wouldn't want to require that these have to be
exposed as separate feature classes.
Thanks,
Orest.
Sent: Wednesday, October 28, 2009 6:07 AM
Subject: [fdo-internals] RE: [mapguide-internals] FDO RFC 43 - Standard FDO
there is another important case which is not covered in RFC.
Same table name in multiple schemas. Also, how to not mess up when users
logs using different credentials.
One way to solve that could be to always use rdbms schema name as fdo schema
name.
I believe it is absolutely necessary that application using FDO to access
rdbms can be sure exactly which table and column it is accessing.
Because what FDO provider sees when connects to rdbms can change regarding
which credentials are used to connect to rdbms. That menas that on same
database it can see only one table, or two tables (same name) in two schemas
or even one or more geometry columns in table.
I am not keen on current naming in King.Oracle with this ~ sign, but I am
very pleased that when using King.Oracle and FDO class trough it, I know
every time exactly which Oracle schema, table and column I am hitting.
Just when wanted to finish something else from RFC:
"Class names for databases are normally tablename, unless qualified which
then has ~COLUMN_NAME appended. (if the are multiple geometries, FDO
requires to know which one is the identifier)"
In King.Oracle ~COLUMN_NAME is appened to make sure resulting name would be
unique. Which actuall oracle column is used is not parsed from name of class
but it is kept inside provider. ~COLUMN_NAME could be anything.
Haris
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, October 28, 2009 9:45 AM
To: FDO Internals Mail List; MapGuide Internals Mail List
Subject: [mapguide-internals] FDO RFC 43 - Standard FDO Class Naming
Conventions
I have posted RFC 43 for review
http://trac.osgeo.org/fdo/wiki/FDORfc43
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
