[fdo-internals] Boost compilation problem & solution
vee_olina violina.ucie at gmail.com
Fri Oct 30 01:16:03 EDT 2009
Hi Alan,
I got the same error, but i found it when i run /.build_linux.sh
I've tried your suggested solution, but I still got the same error..
what's going wrong? help me please
thanks in advance
Alan Boudreault wrote:
> Hi,
> I am a new fdo user and i tryed to compile fdo-3.3.1 under linux ubuntu
> hardy this morning. Here is the errors i've got:
> build_thirdparty.sh :
> Segmentation fault      ./tools/jam/src/bin.linuxx86/bjam toolset=gcc
> variant=release threading=multi ...
> I didn't see this error at the first built. and i tryed to build fdo...
> here is what i've got:
> *** No rule to make target
> `OpenSource_FDO/Thirdparty/boost/stage/lib/libboost_thread-mt.a', needed
> by `libFdoOws.la'.  Stop .... that's normal, boost is not build
> The solution:
> After a moment, I found this bug/patch:
> http://svn.boost.org/trac/boost/ticket/977
> Apply this small patch in
> "Opensource_FDO/Thirdparty/boost/tools/jam/src/" and recompile bjam with
> the "build.sh" script (same directory). Re-run the build_thirdparty.sh
> script and all will be ok and you'll have a boost built.
> Hope this can help some users.
> Regards,
> Alan
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
View this message in context: http://n2.nabble.com/Boost-compilation-problem-solution-tp2051775p3917174.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
