[fdo-internals] RE: [mapguide-internals] FDO RFC 43 - Standard FDO Class Naming Conventions
Zac Spitzer zac.spitzer at gmail.com
Thu Oct 29 20:30:30 EDT 2009
On Fri, Oct 30, 2009 at 1:10 AM, Brent Robinson <brent.robinson at autodesk.com
> wrote:
>  Hi Zac,
> I had a look at RFC 43  and had a few questions regarding the MySQL
> provider:
> 1.       Do the naming conventions apply only to MySQL databases that do
> not have FDO MetaData?
FDO meta data describes a secondary set, I would assume the underlying
tables would be always
exposed in the same fashion..
>  2.       For the statement:
> “MySql? returns schema:tablename or if connected as "schema" then just
> tablename”
> Is “schema” equivalent to a MySQL database?
That was my intention, I rarely use MySQL myself.. similiar to the oracle n
sql server discussions
>  3.       For the case where the tables are exposed as in an empty schema,
> would that mean that the DescribeSchema command would return a Feature
> Schema with blank name? Or would there be a special name to represent the
> empty schema (e.g. “default” or “none”).
thats a really good question! We would want it describable if it's
accessible, blank doesn't seem quite right,
but it does imply the default or none or current...
the unqualified name is a synonym for current_user.table_name
>  4.       What sort of problems are you currently encountering without
> these naming conventions being in place?
As jackie mentioned at the top to the thread, the same data loaded under a
different provider appears different
and thus cannot be just accessed without provider specific knowledge and
coding workarounds
>  a.       Problems copying schemas and features between providers?
yes
> b.      Problems generating statements for the ISQLCommand?
yes
> and a general question: are the conventions intended as standards for all
> DBMS or file base providers or just the ones mentioned in the RFC?
It is intended as a standard for all providers, I have updated the RFC to
reflect that
> If the answer to question 2 is yes then the MySQL provider is currently
> close. The feature schema name is:
> FDO<database_name>
> FDO is prepended to the database name to handle a particular use case
> which, in hindsight, is not likely very common (I’ll describe the use case
> details later). This prefix could therefore be dropped from the feature
> schema name.
> Exposing tables in the current database in an empty schema sounds
> reasonable conceptually.  Some users might not necessarily separate each
> logical schema into a different MySQL database; a database might simply have
> a collection of tables not tied to a particular schema. I have a few
> implementation concerns but I’ll wait for the answer to question 3.
> Switching to the SQLServerSpatial provider, when the database has no FDO
> Metadata, each SQL Server schema is presented as an FDO Feature Schema. No
> special handling is done for the dbo schema. I was curious as to why the dbo
> schema would be non-portable. It would be an unusual name for a logical
> schema but could be copied to a provider, such as SDF, without having to
> rename it.
dbo implies the unqualified schema naming and is meaningless out side sql
server..
ie a database called dbo on mysql or an oracle user called dbo
challenging problem
>  Getting back to the user case mentioned above, it would be the case where
> the schema is copied from a MySQL database without FDO MetaData to a
> database with Metadata, where the two databases have the same name but are
> in different servers. The FDO-enabled databases have a special feature
> schema (with same name as the database) which stores the datastore
> descriptions. This schema is not directly modifiable so the copy would fail
> if the feature schema being copied is named after the source database. To
> handle this, the FDO prefix was added to the schema name. However, as
> mentioned above, this use case is not likely very common.
If you are using meta data, maybe turning it around and exposing metadata
under FDO, also not very pretty
> Brent.
> *From:* fdo-internals-bounces at lists.osgeo.org [mailto:
> fdo-internals-bounces at lists.osgeo.org] *On Behalf Of *Zac Spitzer
> *Sent:* Wednesday, October 28, 2009 10:28 PM
> *To:* FDO Internals Mail List
> *Subject:* Re: [fdo-internals] RE: [mapguide-internals] FDO RFC 43 -
> would introducing the concept of a default schema resolve the issue of
> multiple
> tables having the same name in different schemas? ie GetDefaultSchema()
> Sorry about my confusion about the datastore stuff, my FDO experience
> is predominately from working with MapGuide which doesn't expose them.
> Datastores (databases/instances) also are potentially named differently,
> where as a schema tends to be more consistant.
> If we introduce datastores into FDO Class names I fear things will become
> even more inconsistent. It's easy enough to change the name of a schema,
> but renaming a database is a much bigger change.
> As I described in the Proposed Test case:
> "Expose the Sheboygan dataset via FDO matching the standard conventions"
> is all about achieving the goal of making FDO provider agnostic
> SQL server does present a challenge here with it's three levels, but it if
> it
> has schema shouldn't we present them as schema's? well no because then
> we will be oft returning dbo which is completely non portable.
> z
> On Thu, Oct 29, 2009 at 12:21 PM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
> sounds like another RFC ?
> On Thu, Oct 29, 2009 at 1:04 AM, Orest Halustchak <
> orest.halustchak at autodesk.com> wrote:
> Hi,
> I’d also like to add a comment about something that Haris said in a
> separate reply.
> Ø  Perhaps, providers could return additional info about names of newly
> created classes.
> I think that’s a good idea, maybe a way for ApplySchema to return
> information about anything that was changed from the user’s input.
> Thanks,
> Orest.
> fdo-internals-bounces at lists.osgeo.org] *On Behalf Of *Orest Halustchak
> *Sent:* Wednesday, October 28, 2009 9:39 AM
> *Subject:* RE: [fdo-internals] RE: [mapguide-internals] FDO RFC 43 -
> Hi Zac,
> FDO does have a concept of datastore. There are FDO commands to create,
> destroy, and list datastores. A datastore is also what you open with the
> connection command. It plays a role. My example is meant to show a case of
> two separate FDO datastores that for an rdbms are managed by one rdbms
> server.
> Thanks,
> Orest.
> *Sent:* Wednesday, October 28, 2009 9:15 AM
> inline
> On Wed, Oct 28, 2009 at 11:56 PM, Orest Halustchak <
> Hi,
> Note that there is another qualifier that should be taken into account in
> these discussions and that is the datastore name. There are really three
> levels of qualification: datastore name, schema name, class name. So, cases
> where it is suggested to use the file name as the schema name, if the file
> name is already used for the datastore name, it doesn't have to be used
> again for the schema name.
> My understanding is that FDO has no concept of datastore, it starts with
> schema's
> datastore is defined at the FDO connection level, why squeeze three levels
> into
> a two tier structure?
> An issue with rdbms is that some such as SQL Server include the three
> levels of database, schema, and table. Others such as Oracle do not. So in
> the Oracle case if we map the datastore name to the Oracle user/schema, then
> we should not also use Oracle user/schema for FDO schema.
> Consider this example.
>        FDO Datastore = CityOfNewYork
>                FDO Schema = LandBase
>                        Class = Parcel
>                        Class = Road
>                FDO Schema = Water
>                        Class = Pipe
>                        Class = Valve
>                FDO Schema = Gas
>                        Class = Pipe
>        FDO Datastore = CityOfAlbany
>                Same schemas and classes
> We don't want to mix up the parcels from CityOfNewYork with the parcles
> from CityOfAlbany, those should be in separate tables. Having the Oracle
> schema name as LandBase, Water, and Gas doesn't handle this.
> but that is a problem already solved when you follow the other way other
> database access layers work????
> based on the connection details, either by specifying a datastore, or not
> Pipe would only be accessible if it was the default for the user or the for
> specified datastore. There is a implied concept of the default schema?
> if there's no default and two schemas means there are no schema less tables
> to enumerate
> This is how databases normally work in my experience which is all I'm
> trying
> to suggest with this RFC.
> Also, about the ~ColumnName convention being used for geometry columns,
> note that FDO does allow more than one geometry column per class with one
> flagged as the main geometry. I wouldn't want to require that these have to
> be exposed as separate feature classes.
> Thanks,
> Orest.
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:
> fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> Sent: Wednesday, October 28, 2009 6:07 AM
> To: 'FDO Internals Mail List'
> Subject: [fdo-internals] RE: [mapguide-internals] FDO RFC 43 - Standard FDO
> there is another important case which is not covered in RFC.
> Same table name in multiple schemas. Also, how to not mess up when users
> logs using different credentials.
> One way to solve that could be to always use rdbms schema name as fdo
> schema
> name.
> I believe it is absolutely necessary that application using FDO to access
> rdbms can be sure exactly which table and column it is accessing.
> Because what FDO provider sees when connects to rdbms can change regarding
> which credentials are used to connect to rdbms. That menas that on same
> database it can see only one table, or two tables (same name) in two
> schemas
> or even one or more geometry columns in table.
> I am not keen on current naming in King.Oracle with this ~ sign, but I am
> very pleased that when using King.Oracle and FDO class trough it, I know
> every time exactly which Oracle schema, table and column I am hitting.
> Just when wanted to finish something else from RFC:
> "Class names for databases are normally tablename, unless qualified which
> then has ~COLUMN_NAME appended. (if the are multiple geometries, FDO
> requires to know which one is the identifier)"
> In King.Oracle ~COLUMN_NAME is appened to make sure resulting name would be
> unique. Which actuall oracle column is used is not parsed from name of
> class
> but it is kept inside provider. ~COLUMN_NAME could be anything.
> Haris
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
> Spitzer
> Sent: Wednesday, October 28, 2009 9:45 AM
> To: FDO Internals Mail List; MapGuide Internals Mail List
> Subject: [mapguide-internals] FDO RFC 43 - Standard FDO Class Naming
> Conventions
> I have posted RFC 43 for review
> http://trac.osgeo.org/fdo/wiki/FDORfc43
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
> Zac Spitzer -
> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20091030/6b04b285/attachment-0001.html
More information about the fdo-internals mailing list
