[fdo-internals] RE: [mapguide-internals] FDO Provider naming change with King Oracle
Greg Boone greg.boone at autodesk.com
Wed Sep 23 12:27:51 EDT 2009
So I finally got around to looking into this further. It seems that the official FDO 3.3 and 3.4 releases were published with the King Oracle Provider name being OSGeo.KingOracle. See Revision 4404. The switch to King.Oracle was incorrectly done in revision 4457. This change was incorrect because it no longer matched the name as published in FDO 3.3 and 3.4.
At this point I don't see the solution being to changes the name in the .xml file. I see the solution being to revert the name change made in 4457 to the name found in 4404 and leaving the .xml as is. Otherwise, the published provider name would change from FDO 3.3/3.4 to FDO 3.4.1.
Greg
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, August 04, 2009 9:06 AM
To: MapGuide Internals Mail List; FDO Internals Mail List
Subject: RE: [fdo-internals] RE: [mapguide-internals] FDO Provider naming change with King Oracle
OK. I will make that change and post a patch.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, August 03, 2009 2:06 AM
To: FDO Internals Mail List; MapGuide Internals Mail List
Ah,
thanks Greg.
The existing name was King.Oracle.x.y
This file currently has it as OSGeo.KingOracle.x.y
http://trac.osgeo.org/fdo/browser/branches/3.4/providers.windows.template.xml
If possible, I think it would be best to go back to the King.Oracle.x.y naming in this file to reduce impact for users who have been using this provider since before it was being bundled in the FDO and MapGuide installers, and to match the internal name of the provider.
Jason
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Monday, July 27, 2009 7:14 AM
The name change may possibly have occurred when porting the trunk code back to the 3.4 branch.
	Revision: 4457
	Author: gregboone
	Date: 6:07:10 PM, Thursday, March 19, 2009
	Message:
	Ticket #45: Ported Latest KingOracle Submission to 3.4 Branch
What is the name expected to be? We can revert this change and release a patch if needed.
Greg.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, July 27, 2009 5:20 AM
Subject: [fdo-internals] RE: [mapguide-internals] FDO Provider naming change with King Oracle
That kinda sucks for existing users...
I wonder if this was an intentional change in fdo, or an accidental rename in the template?  I'm tempted to revert to the old value in the MapGuide setup just to limit impact on our users.
Jason
Sent: Monday, July 27, 2009 1:19 AM
Subject: RE: [mapguide-internals] FDO Provider naming change with King Oracle
/me thinks that this information is not actually used when building the FDO
distribution, seeing as the providers.xml template calls it OSGeo.KingOracle
- Jackie
Jason Birch wrote:
> Is that in the latest build only?
> It looks like it's still called King.Oracle in the provider source, so I
> wonder if it's just an oversight in the installer.
> http://trac.osgeo.org/fdo/browser/branches/3.4/Providers/KingOracle/src/Provider/KgOraProvider.h
> Jason
> From: Zac Spitzer
> Sent: Monday, July 27, 2009 12:46 AM
> Subject: [mapguide-internals] FDO Provider naming change with King Oracle
> Just been playing with King Oracle and the 2.1 beta and discovered
> that the naming has changed from King.Oracle to OSGeo.KingOracle
> which broke a lot of my feature sources, probably a good one for the
> release notes. a quick edit of the xml solved the problem
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the fdo-internals mailing list
