[fdo-internals] r4982 - trunk/Providers/PostGIS/Src/Provider
Tom Fukushima tom.fukushima at autodesk.com
Tue Sep 29 09:54:38 EDT 2009
Hi Christophe,
We are getting the following error from this submission:
Connection.cpp:40:41: error: CreateSpatialContextCommand.h: No such file or directory
Connection.cpp: In member function 'virtual FdoICommand* fdo::postgis::Connection::CreateCommand(FdoInt32)':
Connection.cpp:428: error: expected type-specifier before 'CreateSpatialContextCommand'
Connection.cpp:428: error: no match for 'operator=' in 'cmd = (int*)operator new(4u)'
../../../../Fdo/Unmanaged/Inc/Common/Ptr.h:229: note: candidates are: T* FdoPtr<T>::operator=(T*) [with T = FdoICommand]
../../../../Fdo/Unmanaged/Inc/Common/Ptr.h:249: note:                 T* FdoPtr<T>::operator=(const FdoPtr<T>&) [with T = FdoICommand]
Connection.cpp:428: error: expected `;' before 'CreateSpatialContextCommand'
make[2]: *** [Connection.lo] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Could you look into it?  Does a makefile need to be updated?  Usually when a .vcproj file is updated, a corresponding makefile should also be checked.
Thanks
Tom
-----Original Message-----
From: fdo-commits-bounces at lists.osgeo.org [mailto:fdo-commits-bounces at lists.osgeo.org] On Behalf Of svn_fdo at osgeo.org
Sent: Tuesday, September 29, 2009 6:15 AM
To: fdo-commits at lists.osgeo.org
Subject: [fdo-commits] r4982 - trunk/Providers/PostGIS/Src/Provider
Author: scroux
Date: 2009-09-29 08:14:38 -0400 (Tue, 29 Sep 2009)
New Revision: 4982
   trunk/Providers/PostGIS/Src/Provider/Connection.cpp
   trunk/Providers/PostGIS/Src/Provider/Connection.h
   trunk/Providers/PostGIS/Src/Provider/ConnectionCapabilities.cpp
   trunk/Providers/PostGIS/Src/Provider/DescribeSchemaCommand.cpp
   trunk/Providers/PostGIS/Src/Provider/ExpressionProcessor.cpp
   trunk/Providers/PostGIS/Src/Provider/GeometryCapabilities.cpp
   trunk/Providers/PostGIS/Src/Provider/InsertCommand.cpp
   trunk/Providers/PostGIS/Src/Provider/PgTablesReader.cpp
   trunk/Providers/PostGIS/Src/Provider/PgTablesReader.h
   trunk/Providers/PostGIS/Src/Provider/PostGisProvider.h
   trunk/Providers/PostGIS/Src/Provider/PostGisProvider.vcproj
   trunk/Providers/PostGIS/Src/Provider/SQLDataReader.cpp
   trunk/Providers/PostGIS/Src/Provider/SchemaDescription.cpp
   trunk/Providers/PostGIS/Src/Provider/SchemaDescription.h
Modified: trunk/Providers/PostGIS/Src/Provider/PostGisProvider.vcproj
--- trunk/Providers/PostGIS/Src/Provider/PostGisProvider.vcproj	2009-09-29 09:57:47 UTC (rev 4981)
+++ trunk/Providers/PostGIS/Src/Provider/PostGisProvider.vcproj	2009-09-29 12:14:38 UTC (rev 4982)
@@ -445,6 +445,14 @@
 			Name="SpatialContext"
 			<File
+				RelativePath=".\CreateSpatialContextCommand.cpp"
+			</File>
+			<File
+				RelativePath=".\CreateSpatialContextCommand.h"
+			</File>
+			<File
 				RelativePath=".\GetSpatialContextsCommand.cpp"
 			</File>
fdo-commits mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-commits
More information about the fdo-internals mailing list
