[fdo-internals] FDO connect by library
Brent Robinson brent.robinson at autodesk.com
Fri Aug 6 14:31:23 EDT 2010
On Monday, a change will be made to the FDO Connection Manager to allow creating connections from providers that are not registered in providers.xml. CreateConnection() will now accept a library file name, in which case the library will be loaded and the connection retrieved directly from it. The change will be made to the trunk and will be under http://trac.osgeo.org/fdo/ticket/674. There will be no change to existing functionality; CreateConnection() will still accept names of registered providers.
Brent.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20100806/7dfaf248/attachment.html
More information about the fdo-internals mailing list
