[fdo-internals] RFC 52 -- Convenience C++ API wrapper for FDO
Haris Kurtagic
haris at sl-king.com
Mon Aug 9 07:01:29 EDT 2010
Hi Traian,
It is great move, from talk to talk&c++.
I certainly like that you started on coding on this idea. It has be
just talk for some time now :)
My first question would be have you considered having just c interface ?
I quickly went trough code too.
Using one Table per class and keep command and queries in it, sound
like a limiting to have just one query or command per table(class).
Exposing results of query "recordset" trough separate object could be
way to go ?
On side note: I see you are already need "Monday" submit for Fdo
CreateConnection from .dll filename
Thanks,
Haris
On Mon, Aug 9, 2010 at 1:14 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
> Hello all,
> As you know, I have recently complained about FDO API complexity [1]. Complaining is nice and all, but it's better done in C/C++ form, so I have posted a proposal for API simplification as FDO RFC 52. The proposal includes a working draft implementation.
> If interested, have a look, I'd be interested in comments and suggestions for improvement of the design and implementation.
> http://trac.osgeo.org/fdo/wiki/FDORfc52
> Thanks,
> Traian
> [1] http://osgeo-org.1803224.n2.nabble.com/resignation-from-FDO-PSC-td5302376.html#a5302376
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
