[fdo-internals] RE: Object and Association Support
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Tue Aug 17 07:03:05 EDT 2010
Progress and Query...
 * I have used FDO ToolBox to create an FDO schema in SQL Server using the
provider
 * Slight tweak to DFO tb schema editor to deal with identity property
handled not as a collection for objects (will submit separately)
 * I have created Object Properties on a class where the child is a simple
FDO class.
HOWEVER, if the child is a "Feature Class" then the schema will not apply as
an exception is thrown (below).
Is this by design?  Why would you not be able to use a feature class as an
object property but you can as an association property?
 Crispin
{"Class 'Schema_Test:FeatureClass2_Child2', for object property
'Schema_Test:Class_Parent1.TestChild', is not an FdoClass "}
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FW-fdo-users-RE-Object-and-Association-Support-tp5338133p5431536.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
