[fdo-internals] Re: FW: [fdo-users] RE: Object and Association
Support
Brent Robinson
brent.robinson at autodesk.com
Thu Aug 19 16:57:38 EDT 2010
For the Ticket 681 scenario, was the association property specified in the filter or in the property list for the select?
If it was in the filter, the association property by itself cannot be specified, only the properties from the associated class. If you have an association property "assoc1" whose associated class has a property "prop1" then a filter like:
assoc1.prop1 = 1
should work.
If it was in the select list, I'll have a look tomorrow to see how it should be specified.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: Thursday, August 19, 2010 4:17 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Re: FW: [fdo-users] RE: Object and Association Support
Thanks - I have these compiled for SQLServer just some (my) issue means they
don't run at the moment - probably some x64 ODBC related thing...
Though how do the tests run OK based on the ticket I created yesterday?
http://trac.osgeo.org/fdo/ticket/681
It will take me a while to get through the UnitTest implementation so that
will keep me busy...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FW-fdo-users-RE-Object-and-Association-Support-tp5338133p5439330.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
