[fdo-internals] FDO 3.5 final release?
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Aug 31 00:54:37 EDT 2010
Hi Greg,
I am able to build the following:
Windows: MySQL, ODBC, PostgreSQL, GDAL, KingOracle, OGR, PostGIS, SDF, SHP, SQLite, WFS, WMS
Linux: MySQL, ODBC, PostgreSQL*, GDAL, KingOracle, OGR, PostGIS*, SDF, SHP, SQLite, WFS, WMS
*For Linux, I may have build issues with PostgreSQL and PostGIS related to the Thirdparty pgsql libs. I get a number of unresolved externals for both providers and need to investigate further.
Regards,
Trevor
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: August 30, 2010 10:07 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] FDO 3.5 final release?
Trevor,
What builds (minus ArcSDE) are you capable of posting? Why don't we focus on posting what you can build right now.
I can work on posting the ArcSDE libraries once you have posted the main build. I can also look to see if I can reproduce the boost x86 issue so you can perform the win32 build on your win64 machine.
As for testing, I propose we post and have the community validate.
Greg
Sent: Monday, August 30, 2010 11:34 PM
So a number of submissions have been made lately. Are there any objections to having these included in a new candidate build?
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Saturday, August 28, 2010 12:35 PM
Hi Jackie,
Your question is timely. I have been discussing the FDO builds offline with Greg and others over the past few months. Since MapGuide needs FDO for Windows and Linux, I thought it was reasonable for me to do the FDO builds as well. I believe there are a few things we need to address:
1. Build OS for Windows
Currently, the FDO 3.5 builds are cleaner on a 32 bit OS. From what I recall, one of the third party dependencies (boost?) is a bit out of date and gets a little cranky with the (x86) in the path name. I believe this has been resolved in FDO trunk. The 32/64 bit OS wouldn't normally matter but I was foolish enough to install a 64 bit OS on the MapGuide build machine.
We have a couple of options available to resolve this:
a. Set up a separate build VM for FDO with a 32 bit OS.
b. Update the third party libs and compile using the existing MapGuide 64 bit build VM.
Option a. is cleaner and I think it would be better if FDO had its own build machine. I suppose I can eat the licensing cost (bummer).
2. ArcSDE Providers
I do not have access to ESRI SDKs so I cannot build the ESRI FDO Providers. If someone else in the community would be willing to build the ESRI Providers, that would be great.
3. Resourcing
To be honest, I am very busy right now and would welcome a collaborator on the FDO builds. The build infrastructure is web accessible and I would be more than willing to give access to anyone able to help out with the FDO builds.
4. Build Validation
I am competent in FDO but not an FDO expert. And with 10(+?) providers to test, build validation is a major undertaking. We should open up a discussion on appropriate build validation steps. Builds are fine. Builds that work are better.
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: August 28, 2010 2:45 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FDO 3.5 final release?
Hi All,
Is there any word/plans on a final FDO 3.5 release? The download site only has the RC1 release and that itself is several months old now.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-final-release-tp5472205p5472205.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
