[fdo-internals] FDO OGR Provider: NULL values in integer Field
Traian Stanev
traian.stanev at autodesk.com
Mon Feb 22 14:56:45 EST 2010
If I get a chance in the next week, I might port the fix to 3.4 and post a new build of the provider.
Traian
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Monday, February 22, 2010 2:20 PM
To: fdo-internals at lists.osgeo.org
Subject: RE: [fdo-internals] FDO OGR Provider: NULL values in integer Field
I fixed this bug on September 19, 2009. Here is my svn commit (revision 4928) log:
Correct implementation of FdoIFeatureReader::IsNull().
Previously, the function always returned false and then attempts to get a null value would return the default value.
Unfortunately, MapGuide uses ancient builds of FDO.
Traian
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: Monday, February 22, 2010 1:43 PM
Subject: [fdo-internals] FDO OGR Provider: NULL values in integer Field
Hi all,
I'm using FDO 3.4.0 OGR provider to connect to a PostgreSQL db (using a modified GDAL library built with PostgreSQL support).
In fact, I'm using Mapguide Open Source 2.1 that uses FDO 3.4.0.
I'm trying to stylize a layer in Mapguide, aka doing a query that involves searching for NULL (and NOT NULL) values in an integer field of a PostgreSQL table.
After a lot of fiddling it seems that tuples with NULL values can be retrieved only searching for tuples that have the value 0 in that field.
This is obviously very odd since 0 is a valid integer, so it appears that I cannot distinguish tuples with proper zeros in the field from tuples with unknown values.
Moreover ogr itself is able to support NULL values correctly.
I've read this previous thread
http://n2.nabble.com/RE-mapguide-internals-Exception-thrown-on-null-values-tp2051195p2051195.html.
Is FDO OGR provider avoiding NULL value intricacy when dealing with integer fields converting the NULL value in a zero?
Do you suggest opening a bug against FDO OGR provider or it is a by-design behaviour of FDO OGR provider?
Regards,
Gabriele
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
